Pine64 PinePhone Volume Buttons Replacement
  1. Pine64 PinePhone Volume Buttons Replacement, Back Cover: step 1, image 1 of 2 Pine64 PinePhone Volume Buttons Replacement, Back Cover: step 1, image 2 of 2
    • Place the device face down on a non-scratch surface.
  2. Pine64 PinePhone Volume Buttons Replacement: step 2, image 1 of 1
    • Using a fingernail pry open the back cover off with the bottom left indent.
  3. Pine64 PinePhone Volume Buttons Replacement, Battery: step 3, image 1 of 1
    • Using a fingernail, press into the bottom divot and remove the battery from the phone.
  4. Pine64 PinePhone Volume Buttons Replacement, Motherboard: step 4, image 1 of 1
    • Use a spudger or plastic opening tool to pry off the plastic cover.
  5. Pine64 PinePhone Volume Buttons Replacement: step 5, image 1 of 1
    • Use a spudger to lift the ZIF tabs and press-fit connectors free.
  6. Pine64 PinePhone Volume Buttons Replacement: step 6, image 1 of 1
    • Use a spudger to lift the motherboard up and remove it from the device.
  7. Pine64 PinePhone Volume Buttons Replacement, Volume Buttons: step 7, image 1 of 1
    • Use a spudger to gently pry the volume button off of the phone.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 276
