Pine64 PineTab 2 Touch & Front Glass Replacement
Zehka
Zehka and one other contributor
Last updated on September 3, 2024
45 minutes
Moderate
Community-Contributed Guide
Introduction
Go to step 1
This guide shows you how to replace a broken front glass and touch module but most disassembly steps are valid for other repair such as changing the screen as welll and can be easily adapted.
    • Shut your device off
    • Remove the SD-Card
  1. Pine64 PineTab 2 Touch & Front Glass Replacement, Unclip the front panel: step 2, image 1 of 1
    • Use the opening tool to lift the panel from the back cover
    • The panel is clipped to the frame so you should feel the clips release
    • Sliding the opening tool sideways after opening the first clips helps opening others
    • You will need to open clips on all 4 sides
  2. Pine64 PineTab 2 Touch & Front Glass Replacement, Open the device: step 3, image 1 of 1
    • Lift the panel out of the back and put it on a soft surface with the glass down without stretching the flex cable connecting the back and the mainboard
    • The element forming the three buttons will probably fall out at this point. Put it aside but remember to put it back into the back cover before closing the device
  3. Pine64 PineTab 2 Touch & Front Glass Replacement, Remove the wifi antenna: step 4, image 1 of 1
    • The wifi antenna is glued to the frame
    • Carefully peel it of without tearing it apart
    • It is sticky enough to hold again later without extra glue
  4. Pine64 PineTab 2 Touch & Front Glass Replacement, Remove the front camera and speakers: step 5, image 1 of 1
    • Unscrew the speaker (mounted at the top with metal surfaces)
    • Lift the front camera out of its hole. It has no screws or clips
    • Move those parts inwards so they rest on the back of the LCD
  5. Pine64 PineTab 2 Touch & Front Glass Replacement, Remove the back camera holder and headphone jack: step 6, image 1 of 2 Pine64 PineTab 2 Touch & Front Glass Replacement, Remove the back camera holder and headphone jack: step 6, image 2 of 2
    • Unscrew and lift aside the black plastic that holds the back camera in place
    • The camera itself can remain
    • Remove the washer screw holding the headphone jack in place (next to the camera)
  6. Pine64 PineTab 2 Touch & Front Glass Replacement, Remove the round sensor and free the speaker cables: step 7, image 1 of 1
    • Carefully lift the round sensor from its position in the frame
    • Remove the speaker cables from their trenches in the black support element, it may be covered by tape
    • Unscrew the element and put it aside
  7. Pine64 PineTab 2 Touch & Front Glass Replacement, Remove the touch connector flat cable: step 8, image 1 of 1
    • Remove the flat cable connecting the touch from the mainboard by flipping up the black latch holding it in place
  8. Pine64 PineTab 2 Touch & Front Glass Replacement, Unscrew the mainboard: step 9, image 1 of 1
    • Remove the screws holding the mainboard
    • Lift it up carefully to access the LCD clips underneath
  9. Pine64 PineTab 2 Touch & Front Glass Replacement, Remove the LCD from the front glass: step 10, image 1 of 1
    • Unclip the LCD panel from the front glass panel by carefully wedging an opening pick between the panel and the clips holding it in place
    • You can now swap the front glass and touch unit
    • The replacement unit has a protective foil on the inside. You need to remove that before installing the new glass
    • The foil started to leave residue on the glass so i used a hair dryer to weaken the glue
Congratulations you now have a touch device again
Zehka
231 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 125
