Pioneer A1 XW-SMA1-K Antenna Replacement
  1. Pioneer A1 XW-SMA1-K Antenna Replacement, Back Panel: step 1, image 1 of 1
    • Use the spudger to remove the mesh front panel.
  2. Pioneer A1 XW-SMA1-K Antenna Replacement: step 2, image 1 of 2 Pioneer A1 XW-SMA1-K Antenna Replacement: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the thirteen 12 mm screws in the speaker frame.
    • Remove the speaker frame by pulling vertically upwards revealing the motherboard.
  3. Pioneer A1 XW-SMA1-K Antenna Replacement: step 3, image 1 of 3 Pioneer A1 XW-SMA1-K Antenna Replacement: step 3, image 2 of 3 Pioneer A1 XW-SMA1-K Antenna Replacement: step 3, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the twelve 12 mm screws from the middle frame.
    • Remove the middle frame by pulling upward and vertically.
  4. Pioneer A1 XW-SMA1-K Antenna Replacement: step 4, image 1 of 2 Pioneer A1 XW-SMA1-K Antenna Replacement: step 4, image 2 of 2
    • Use the Phillips #1 screwdriver to remove the nine 12 mm screws from the motherboard.
    • Flip the motherboard over.
    • Remove the motherboard by detaching the antenna.
  5. Pioneer A1 XW-SMA1-K Antenna Replacement, Motherboard: step 5, image 1 of 1
    • Remove the motherboard from the speaker.
  6. Pioneer A1 XW-SMA1-K Antenna Replacement, Antenna: step 6, image 1 of 2 Pioneer A1 XW-SMA1-K Antenna Replacement, Antenna: step 6, image 2 of 2
    • Flip over the back panel and pull the antenna up and out.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 561
