Pioneer Steel Wheels Headphone Headband Replacement
  1. Pioneer Steel Wheels Headphone Headband Replacement, Headband: step 1, image 1 of 2 Pioneer Steel Wheels Headphone Headband Replacement, Headband: step 1, image 2 of 2
    • Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
  2. Pioneer Steel Wheels Headphone Headband Replacement: step 2, image 1 of 2 Pioneer Steel Wheels Headphone Headband Replacement: step 2, image 2 of 2
    • With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
    • With force, pull upwards.
  3. Pioneer Steel Wheels Headphone Headband Replacement: step 3, image 1 of 3 Pioneer Steel Wheels Headphone Headband Replacement: step 3, image 2 of 3 Pioneer Steel Wheels Headphone Headband Replacement: step 3, image 3 of 3
    • Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
    • Repeat on the opposite side and the headband will be released.
    • During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
Garrett Leung
955 Reputation
8 Guides authored
Cal Poly, Team 10-40, Amido Spring 2013 Member of Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Members
37 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 16
All Time: 1,184
