Plantronics CS50 Headset Battery Replacement
  1. Plantronics CS50 Headset Battery Replacement, Battery: step 1, image 1 of 3 Plantronics CS50 Headset Battery Replacement, Battery: step 1, image 2 of 3 Plantronics CS50 Headset Battery Replacement, Battery: step 1, image 3 of 3
    • Flip the headset face down.
    • Squeeze both sides of the battery cover.
    • While squeezing, pull the cover up slowly to remove it.
  2. Plantronics CS50 Headset Battery Replacement: step 2, image 1 of 3 Plantronics CS50 Headset Battery Replacement: step 2, image 2 of 3 Plantronics CS50 Headset Battery Replacement: step 2, image 3 of 3
    • Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
To reassemble your device, follow these instructions in reverse order
2 other people completed this guide.
Yuliya Levitskaya
77 Reputation
2 Guides authored
Cal Poly, Team 17-29, Amido Spring 2012 Member of Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Members
7 Guides authored
2 Guide Comments
I created the article https://de.ifixit.com/Artikel/Battery_Pl... for a Silvercrest bluetooth transmitter, but I was not able to change the needed parts of this howto to link to that article.
anton2 - Reply
I replaced the battery with a new battery, I cleaned all the connectors and I reset the base and the headset is still not working
Lee kathryn lucas - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 7,980
