Plantronics CS50 Headset Motherboard of the Base Unit Replacement
  1. Plantronics CS50 Headset Motherboard of the Base Unit Replacement, Motherboard of the Base Unit: step 1, image 1 of 2 Plantronics CS50 Headset Motherboard of the Base Unit Replacement, Motherboard of the Base Unit: step 1, image 2 of 2
    • Flip over the base unit to reveal the bottom.
  2. Plantronics CS50 Headset Motherboard of the Base Unit Replacement: step 2, image 1 of 2 Plantronics CS50 Headset Motherboard of the Base Unit Replacement: step 2, image 2 of 2
    • Using a #0 screwdriver, remove the two 2.50mm screws.
  3. Plantronics CS50 Headset Motherboard of the Base Unit Replacement: step 3, image 1 of 3 Plantronics CS50 Headset Motherboard of the Base Unit Replacement: step 3, image 2 of 3 Plantronics CS50 Headset Motherboard of the Base Unit Replacement: step 3, image 3 of 3
    • Separate, but do not remove, the silver upper piece from the dark lower piece.
    • Carefully disconnect the wires from the motherboard.
    • Remove the silver top of the base.
  4. Plantronics CS50 Headset Motherboard of the Base Unit Replacement: step 4, image 1 of 3 Plantronics CS50 Headset Motherboard of the Base Unit Replacement: step 4, image 2 of 3 Plantronics CS50 Headset Motherboard of the Base Unit Replacement: step 4, image 3 of 3
    • Remove the motherboard from the base
Bryan Clark
45 Reputation
1 Guide authored
Cal Poly, Team 17-29, Amido Spring 2012 Member of Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,067
