Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement
  1. Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement, Overview: step 1, image 1 of 2 Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement, Overview: step 1, image 2 of 2
    • This guide is only to replace the Stick button
  2. Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: step 2, image 1 of 3 Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: step 2, image 2 of 3 Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: step 2, image 3 of 3
    • Open the little holders
    • then carefully lift the metal plate
  3. Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: step 3, image 1 of 3 Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: step 3, image 2 of 3 Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: step 3, image 3 of 3
    • Take out the small Springs and pry it open . I marked the direction .
  4. Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: step 4, image 1 of 3 Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: step 4, image 2 of 3 Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Lift up this metal holder, donĀ“t bend it.
    • Then with tweezers detach the white plastic. It holds the Analog cap.
    • One end of the white plastic is magnetic. Do not damage it
  5. Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: step 5, image 1 of 2 Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: step 5, image 2 of 2
    • Turn the cap and replace it with a new one.
    • * If Sony did not did this thing with the Analog Cap turning we could simply pull out the Cap and place a new one.
    • Assembly is simple like the disassembly :D
cakone micke
241 Reputation
1 Guide authored
One Comment
Marked as easy? Does it look harder than it is? Looks like it requires alot of precision
Shebaz Raza - Reply
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 187
All Time: 4,053
