PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement
  1. PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement, Lower Smart Plate: step 1, image 1 of 1
    • Turn off your PlayStation 2 and remove the disc and Memory Card.
    • Turn over the PlayStation 2 and put it on a soft surface (e.g. a towel).
  2. PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement: step 2, image 1 of 1
    • Locate the six covers.
    • Two are located underneath the feet.
    • One cover is located underneath the Void sticker.
  3. PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement: step 3, image 1 of 1
    • Remove the Void sticker with a Spudger and some cleaning alcohol
    • Removing the Void sticker will void the warranty of your device!
    • Some versions of that console maybe don’t have the sticker or it’s relocated.
  4. PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement: step 4, image 1 of 2 PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement: step 4, image 2 of 2
    • Remove the covers by using either a Spudger, Opening Picks or your fingernail.
  5. PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement: step 5, image 1 of 1
    • Remove the six Phillips #1 screws with a screwdriver.
    • The screws on the right are a bit deeper inside the shell as like the rest but are the same size.
  6. PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement: step 6, image 1 of 2 PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement: step 6, image 2 of 2
    • Separate the clips at the front and the overhanging side from their mounting using a Prying Tool.
    • Separate the two halves.
  7. PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement, Fan: step 7, image 1 of 1
    • Pull the ribbon cable straight out from the socket.
    • To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable. If you can, apply the force to the plastic reinforcement rather than the cable itself.
  8. PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement: step 8, image 1 of 1
    • Remove three Phillips #0 screws securing the fan.
    • Lift the fan straight up and out of the PS2.
  9. PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement, Power Supply: step 10, image 1 of 1
    • Remove the Phillips screw from the power supply.
  10. PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement: step 11, image 1 of 1
    • Remove the power supply connector from the motherboard.
    • To separate the connector from its socket, squeeze the tab against the connector, and pull the connector straight up from the socket.
    • Lift the power supply straight up and out of the PS2.
  11. PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement, Optical Drive: step 13, image 1 of 1
    • Pull the two ribbon cables straight out from their sockets.
    • To reinstall the cables, hold it near the end and push it straight into the connector, being careful not to kink the cable. If you can, apply the force to the plastic reinforcement rather than the cable itself.
  12. PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement: step 14, image 1 of 2 PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement: step 14, image 2 of 2
    • Turn around the PS2 by 180 degrees.
    • Lift the optical drive up from its four mountings.
    • Remove the glued ribbon cable from the EMI shield using a spudger and some isopropyl alcohol.
  13. PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement: step 15, image 1 of 2 PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement: step 15, image 2 of 2
    • Finally remove the optical drive from the PS2.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
MrJulian is helping us fix the world! Want to contribute?
Start translating ›
MrJulian
1,660 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 28
Past 30 Days: 185
All Time: 1,443
