PlayStation 2 Slimline SCPH-900xx Power Supply Replacement
  1. PlayStation 2 Slimline SCPH-900xx Power Supply Replacement, Lower Smart Plate: step 1, image 1 of 1
    • Turn off your PlayStation 2 and remove the disc and Memory Card.
    • Turn over the PlayStation 2 and put it on a soft surface (e.g. a towel).
  2. PlayStation 2 Slimline SCPH-900xx Power Supply Replacement: step 2, image 1 of 1
    • Locate the six covers.
    • Two are located underneath the feet.
    • One cover is located underneath the Void sticker.
  3. PlayStation 2 Slimline SCPH-900xx Power Supply Replacement: step 3, image 1 of 1
    • Remove the Void sticker with a Spudger and some cleaning alcohol
    • Removing the Void sticker will void the warranty of your device!
    • Some versions of that console maybe don’t have the sticker or it’s relocated.
  4. PlayStation 2 Slimline SCPH-900xx Power Supply Replacement: step 4, image 1 of 2 PlayStation 2 Slimline SCPH-900xx Power Supply Replacement: step 4, image 2 of 2
    • Remove the covers by using either a Spudger, Opening Picks or your fingernail.
  5. PlayStation 2 Slimline SCPH-900xx Power Supply Replacement: step 5, image 1 of 1
    • Remove the six Phillips #1 screws with a screwdriver.
    • The screws on the right are a bit deeper inside the shell as like the rest but are the same size.
  6. PlayStation 2 Slimline SCPH-900xx Power Supply Replacement: step 6, image 1 of 2 PlayStation 2 Slimline SCPH-900xx Power Supply Replacement: step 6, image 2 of 2
    • Separate the clips at the front and the overhanging side from their mounting using a Prying Tool.
    • Separate the two halves.
  7. PlayStation 2 Slimline SCPH-900xx Power Supply Replacement, Power Supply: step 7, image 1 of 1
    • Remove the Phillips screw from the power supply.
  8. PlayStation 2 Slimline SCPH-900xx Power Supply Replacement: step 8, image 1 of 1
    • Remove the power supply connector from the motherboard.
    • To separate the connector from its socket, squeeze the tab against the connector, and pull the connector straight up from the socket.
    • Lift the power supply straight up and out of the PS2.
5 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
MrJulian
2,157 Reputation
7 Guides authored
One Comment
I remember i was open the PS2 for cleaning but when i cleaning the power supply, my sister plugged it than I got an electric shock. 🤣🤣🤣
Memozit - Reply
Past 24 Hours: 12
Past 7 Days: 52
Past 30 Days: 132
All Time: 1,755
