PlayStation 3 Slim - Manually Removing Stuck Disk
Video Overview
  1. PlayStation 3 Slim - Manually Removing Stuck Disk, PlayStation 3 Slim - Manually Removing Stuck Disk: step 1, image 1 of 3 PlayStation 3 Slim - Manually Removing Stuck Disk, PlayStation 3 Slim - Manually Removing Stuck Disk: step 1, image 2 of 3 PlayStation 3 Slim - Manually Removing Stuck Disk, PlayStation 3 Slim - Manually Removing Stuck Disk: step 1, image 3 of 3
    • Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
  2. PlayStation 3 Slim - Manually Removing Stuck Disk: step 2, image 1 of 3 PlayStation 3 Slim - Manually Removing Stuck Disk: step 2, image 2 of 3 PlayStation 3 Slim - Manually Removing Stuck Disk: step 2, image 3 of 3
    • Unscrew the three screws. To remove Blu Ray unit shell you must open two plates that are on the left and right side.
  3. PlayStation 3 Slim - Manually Removing Stuck Disk: step 3, image 1 of 3 PlayStation 3 Slim - Manually Removing Stuck Disk: step 3, image 2 of 3 PlayStation 3 Slim - Manually Removing Stuck Disk: step 3, image 3 of 3
    • First remove the spindle disc magnet. Now use plastic tool and slowly extrude the disk from inside.
  4. PlayStation 3 Slim - Manually Removing Stuck Disk: step 4, image 1 of 2 PlayStation 3 Slim - Manually Removing Stuck Disk: step 4, image 2 of 2
    • In this case we have ... 4x disks. :)
    • Did you do it successfully?
  5. PlayStation 3 Slim - Manually Removing Stuck Disk: step 5, image 1 of 2 PlayStation 3 Slim - Manually Removing Stuck Disk: step 5, image 2 of 2
    • Test the console before assembling. And don't forget to put the spindle disc magnet.
18 other people completed this guide.
ZFix
191,882 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,516 Guides authored
One Comment
muuito bom o tutorial
Z&x Archives - Reply
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 150
All Time: 27,228
