You're viewing a previously published version of this guide.  View latest version
Older Newer
PlayStation 3 Smart Plate Replacement
Walter Galan
Walter Galan and 8 other contributors
Last updated on May 6, 2024
10 minutes
Moderate
Introduction
Go to step 1
Use this guide to replace your PlayStation 3's smart plate.
Tools
  1. PlayStation 3 Smart Plate Replacement, Smart Plate: step 1, image 1 of 2 PlayStation 3 Smart Plate Replacement, Smart Plate: step 1, image 2 of 2
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Smart Plate Replacement: step 2, image 1 of 1
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Smart Plate Replacement: step 3, image 1 of 3 PlayStation 3 Smart Plate Replacement: step 3, image 2 of 3 PlayStation 3 Smart Plate Replacement: step 3, image 3 of 3
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Smart Plate Replacement: step 4, image 1 of 1
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
Past 24 Hours: 4
Past 7 Days: 35
Past 30 Days: 150
All Time: 26,199
