PlayStation 3 Super Slim Laser Lens Replacement
  1. PlayStation 3 Super Slim Laser Lens Replacement, Power Supply Unit: step 1, image 1 of 2 PlayStation 3 Super Slim Laser Lens Replacement, Power Supply Unit: step 1, image 2 of 2
    • Remove the side HDD bay cover by sliding the panel towards the back of the device.
    • The bay cover is found on the right side of the device.
  2. PlayStation 3 Super Slim Laser Lens Replacement: step 2, image 1 of 2 PlayStation 3 Super Slim Laser Lens Replacement: step 2, image 2 of 2
    • Remove all three black 9.8mm long screws with a T-8 security screwdriver.
    • Remove the blue 7.9mm long screw with a Phillips #1 screwdriver.
  3. PlayStation 3 Super Slim Laser Lens Replacement: step 3, image 1 of 2 PlayStation 3 Super Slim Laser Lens Replacement: step 3, image 2 of 2
    • Pull on the tab to remove the HDD.
    • The HDD should be removed and stored carefully to prevent damage to data.
  4. PlayStation 3 Super Slim Laser Lens Replacement: step 4, image 1 of 2 PlayStation 3 Super Slim Laser Lens Replacement: step 4, image 2 of 2
    • On the bottom of the device, pry out the three rubber feet covers with the metal spudger.
    • Remove the four black 36.3mm long screws underneath with a Phillips #1 screwdriver.
    • One screw is located underneath the warranty sticker. This sticker can either be peeled off or punctured through with a screwdriver.
  5. PlayStation 3 Super Slim Laser Lens Replacement: step 5, image 1 of 2 PlayStation 3 Super Slim Laser Lens Replacement: step 5, image 2 of 2
    • On the top of the device, unlatch the hook on the furthest right beneath the front panel, lift the panel slightly and apply pressure.
    • Unlatch the second right-side hook by sliding a plastic opening tool in the marked area.
    • Slide the panel to the left to unlatch the rest of the hooks.
    • This is probably the most difficult part of the procedure. If you cannot unlatch the hook on the front panel, you can attempt to pry all the hooks off. However, do this at your own risk, as these hooks break easily.
  6. PlayStation 3 Super Slim Laser Lens Replacement: step 6, image 1 of 1
    • Remove the back panel by pressing down the tab on the right side of the device, and sliding the panel to the left.
  7. PlayStation 3 Super Slim Laser Lens Replacement: step 7, image 1 of 3 PlayStation 3 Super Slim Laser Lens Replacement: step 7, image 2 of 3 PlayStation 3 Super Slim Laser Lens Replacement: step 7, image 3 of 3
    • Remove the five silver 20.8mm long screws with a Phillips #1 screwdriver.
    • Remove the two black 9.9mm long screws in the disc reader with a T-8 security screwdriver.
    • Remove the top black plastic shell.
  8. PlayStation 3 Super Slim Laser Lens Replacement: step 8, image 1 of 3 PlayStation 3 Super Slim Laser Lens Replacement: step 8, image 2 of 3 PlayStation 3 Super Slim Laser Lens Replacement: step 8, image 3 of 3
    • Move the optical drive to the side to reveal one of the silver 8.8mm long screws.
    • Remove the two silver 8.8mm long screws on either side with a Phillips #1 screwdriver.
  9. PlayStation 3 Super Slim Laser Lens Replacement: step 9, image 1 of 3 PlayStation 3 Super Slim Laser Lens Replacement: step 9, image 2 of 3 PlayStation 3 Super Slim Laser Lens Replacement: step 9, image 3 of 3
    • Remove the cable from the plug and remove the wires from the two plastic hooks.
    • When removing the cable from the plug, pull on the plastic male connecter, not on the wires.
    • Remove the power supply unit.
  10. PlayStation 3 Super Slim Laser Lens Replacement, Optical Drive: step 10, image 1 of 3 PlayStation 3 Super Slim Laser Lens Replacement, Optical Drive: step 10, image 2 of 3 PlayStation 3 Super Slim Laser Lens Replacement, Optical Drive: step 10, image 3 of 3
    • Remove the front white flex-ribbon cable by pulling upward from its base.
    • Remove the black and blue flex-ribbon cable behind it by pulling upward on the black tab, then pulling out the cable.
  11. PlayStation 3 Super Slim Laser Lens Replacement: step 11, image 1 of 3 PlayStation 3 Super Slim Laser Lens Replacement: step 11, image 2 of 3 PlayStation 3 Super Slim Laser Lens Replacement: step 11, image 3 of 3
    • Rotate the device 180 degrees.
    • Remove the back white flex-ribbon cable by pulling upward from its base.
    • Remove the optical drive.
  12. PlayStation 3 Super Slim Laser Lens Replacement, Laser Lens: step 12, image 1 of 3 PlayStation 3 Super Slim Laser Lens Replacement, Laser Lens: step 12, image 2 of 3 PlayStation 3 Super Slim Laser Lens Replacement, Laser Lens: step 12, image 3 of 3
    • Lift up the free end of the laser lens to separate the two layers.
    • On the bottom of the laser lens, flip up the black plastic latch to remove the flex ribbon cable.
  13. PlayStation 3 Super Slim Laser Lens Replacement: step 13, image 1 of 3 PlayStation 3 Super Slim Laser Lens Replacement: step 13, image 2 of 3 PlayStation 3 Super Slim Laser Lens Replacement: step 13, image 3 of 3
    • Remove the 4 rubber bushings.
    • Remove the metal faceplate from the laser lens.
    • When inserting your new lens, attach the top metal casing to the replacement laser lens.
6 other people completed this guide.
Joseph O'Connor
2,479 Reputation
5 Guides authored
Cal Poly, Team 34-13, Maness Spring 2016 Member of Cal Poly, Team 34-13, Maness Spring 2016
CPSU-MANESS-S16S34G13
4 Members
21 Guides authored
6 Comments
so i did follow this to a tee and not only does the laser not want to work but it keeps makeing this buzzing sound whenever the disk tray is closed
is there something i might be doing wrong
dave raschke - Reply
Very Good but please show us how to remove lens only
wtersad - Reply
like the video,
Where is the parts purchased from?
Thanks Joe
jdpassanisi - Reply
Laser is KEM-850a. You can order them from ebay. gamesunlimited and ep game supply are good stores. You can also order these from groupvertical.com or sourcleyplus.com
Eddie Switek -
I am replacing the optical drive in my console. But didn't note where the drive ribbon was positioned!? Every video I have found, they just pop right in...my original and replacement drives, have larger receptacles than the ribbon it self. There are at least 5 pins, that don't have (potentially) anything connecting them, to the ribbon. I don't want to randomly place the ribbon in one of the possible (7?) positions and fry something in the process...so where do I connect the smaller ribbon?!
Robert Shelton - Reply
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 182
All Time: 10,870
