iMac Intel 21.5" EMC 2805 Fan Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. iMac Intel 21.5" EMC 2805 Fan Replacement, Fan: step 1, image 1 of 2 iMac Intel 21.5" EMC 2805 Fan Replacement, Fan: step 1, image 2 of 2
    • Use the tip of a spudger to push the fan cable connector out of its socket on the logic board.
    • It is recommended to carefully push on both sides of the connector to walk it out of its socket.
  2. iMac Intel 21.5" EMC 2805 Fan Replacement: step 2, image 1 of 1
    • Remove the following screws securing the fan to the rear enclosure:
    • Two 12.5 mm T10 screws
    • One 9.9 mm T10 screw
  3. iMac Intel 21.5" EMC 2805 Fan Replacement: step 3, image 1 of 2 iMac Intel 21.5" EMC 2805 Fan Replacement: step 3, image 2 of 2
    • Lift and remove the fan from the iMac.
Walter Galan
706,493 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 89
