PlayStation 4 Slim Optical Disc Drive Replacement
  1. PlayStation 4 Slim Optical Disc Drive Replacement, Bottom Cover: step 1, image 1 of 3 PlayStation 4 Slim Optical Disc Drive Replacement, Bottom Cover: step 1, image 2 of 3 PlayStation 4 Slim Optical Disc Drive Replacement, Bottom Cover: step 1, image 3 of 3
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
  2. PlayStation 4 Slim Optical Disc Drive Replacement: step 2, image 1 of 2 PlayStation 4 Slim Optical Disc Drive Replacement: step 2, image 2 of 2
    • Unscrew and remove the now exposed 5.0mm screw using a TR8 security Torx screwdriver with a counter-clockwise motion.
  3. PlayStation 4 Slim Optical Disc Drive Replacement: step 3, image 1 of 3 PlayStation 4 Slim Optical Disc Drive Replacement: step 3, image 2 of 3 PlayStation 4 Slim Optical Disc Drive Replacement: step 3, image 3 of 3
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
  4. PlayStation 4 Slim Optical Disc Drive Replacement, Power Supply: step 4, image 1 of 3 PlayStation 4 Slim Optical Disc Drive Replacement, Power Supply: step 4, image 2 of 3 PlayStation 4 Slim Optical Disc Drive Replacement, Power Supply: step 4, image 3 of 3
    • Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
    • This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
    • Remove the top cover by sliding it towards the back corners and lifting up.
  5. PlayStation 4 Slim Optical Disc Drive Replacement: step 5, image 1 of 3 PlayStation 4 Slim Optical Disc Drive Replacement: step 5, image 2 of 3 PlayStation 4 Slim Optical Disc Drive Replacement: step 5, image 3 of 3
    • Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  6. PlayStation 4 Slim Optical Disc Drive Replacement: step 6, image 1 of 1
    • Remove the four 16mm Philips screws holding the power supply in place.
  7. PlayStation 4 Slim Optical Disc Drive Replacement: step 7, image 1 of 2 PlayStation 4 Slim Optical Disc Drive Replacement: step 7, image 2 of 2
    • Remove the metal sheet from the top of the power supply by grabbing and lifting up with your hands.
  8. PlayStation 4 Slim Optical Disc Drive Replacement: step 8, image 1 of 2 PlayStation 4 Slim Optical Disc Drive Replacement: step 8, image 2 of 2
    • Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
  9. PlayStation 4 Slim Optical Disc Drive Replacement: step 9, image 1 of 2 PlayStation 4 Slim Optical Disc Drive Replacement: step 9, image 2 of 2
    • Flip the Playstation 4 Slim onto its back.
    • Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  10. PlayStation 4 Slim Optical Disc Drive Replacement: step 10, image 1 of 3 PlayStation 4 Slim Optical Disc Drive Replacement: step 10, image 2 of 3 PlayStation 4 Slim Optical Disc Drive Replacement: step 10, image 3 of 3
    • Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two.
    • Lift the power supply up and onto its back on the metal sheet using your hands.
  11. PlayStation 4 Slim Optical Disc Drive Replacement: step 11, image 1 of 3 PlayStation 4 Slim Optical Disc Drive Replacement: step 11, image 2 of 3 PlayStation 4 Slim Optical Disc Drive Replacement: step 11, image 3 of 3
    Tool used on this step:
    Buy
    • Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out.
    • Remove the power supply completely by grabbing and lifting up with your hands.
  12. PlayStation 4 Slim Optical Disc Drive Replacement, Optical Disc Drive: step 12, image 1 of 2 PlayStation 4 Slim Optical Disc Drive Replacement, Optical Disc Drive: step 12, image 2 of 2
    • Unscrew and remove the 31.0mm screw using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 10x 5.0mm screws using a Phillips #1 screwdriver with a counter-clockwise motion.
  13. PlayStation 4 Slim Optical Disc Drive Replacement: step 13, image 1 of 2 PlayStation 4 Slim Optical Disc Drive Replacement: step 13, image 2 of 2
    • Remove the metal plate by grabbing the edges and lifting up with your hands.
  14. PlayStation 4 Slim Optical Disc Drive Replacement: step 14, image 1 of 2 PlayStation 4 Slim Optical Disc Drive Replacement: step 14, image 2 of 2
    • Unscrew and remove the two 3.0mm screws using a PH000 screwdriver with a counter-clockwise motion.
  15. PlayStation 4 Slim Optical Disc Drive Replacement: step 15, image 1 of 2 PlayStation 4 Slim Optical Disc Drive Replacement: step 15, image 2 of 2
    • Remove the disk drive out by pinching on either side of the two black plastic "claws" and lifting up with your hand.
92 other people completed this guide.
Hernan Rodriguez
3,760 Reputation
3 Guides authored
Cal Poly, Team S19-G4, Livingston Winter 2018 Member of Cal Poly, Team S19-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G4
4 Members
35 Guides authored
24 Comments
incomplete guide, what replacement? the last step is taking the cover off but what about the disk drive?
Yegor Ilchuk - Reply
Yeah, where's the ending to this?
Ben Baptist - Reply
To remove the complete drive you have to remove the motherboard. with the motherboard removed some of the above steps may not be necessary.
This guide is useful if you just need to remove disc or clean laser.
Freddie Parsons - Reply
when replacing do you have to swap a board like the PS4’s of the past?
Frank Ferrante - Reply
Nope, on the ps4 slim the optical drive is not married to the motherboard so any drive as long is the same model will work with any motherboard
Joshua Sites -
Past 24 Hours: 61
Past 7 Days: 445
Past 30 Days: 2,074
All Time: 177,696
