PlayStation 5 (2021 revision) Fan Replacement
  1. PlayStation 5 (2021 revision) Fan Replacement, Remove the stand screw: step 1, image 1 of 1
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. PlayStation 5 (2021 revision) Fan Replacement, Remove the vertical stand: step 2, image 1 of 2 PlayStation 5 (2021 revision) Fan Replacement, Remove the vertical stand: step 2, image 2 of 2
    • Lift straight up to remove the stand.
  3. PlayStation 5 (2021 revision) Fan Replacement, Store the stand screw: step 3, image 1 of 2 PlayStation 5 (2021 revision) Fan Replacement, Store the stand screw: step 3, image 2 of 2
    • Insert the screw into the cubby on the bottom of the stand.
  4. PlayStation 5 (2021 revision) Fan Replacement, Cap the screw hole: step 4, image 1 of 3 PlayStation 5 (2021 revision) Fan Replacement, Cap the screw hole: step 4, image 2 of 3 PlayStation 5 (2021 revision) Fan Replacement, Cap the screw hole: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. PlayStation 5 (2021 revision) Fan Replacement, Close the cubby: step 5, image 1 of 3 PlayStation 5 (2021 revision) Fan Replacement, Close the cubby: step 5, image 2 of 3 PlayStation 5 (2021 revision) Fan Replacement, Close the cubby: step 5, image 3 of 3
    • Twist the stand counterclockwise to close the cubby.
  6. PlayStation 5 (2021 revision) Fan Replacement, Remove the horizontal stand: step 6, image 1 of 2 PlayStation 5 (2021 revision) Fan Replacement, Remove the horizontal stand: step 6, image 2 of 2
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
David Fear
4,507 Reputation
8 Guides authored
Pickle IT - Gadget Repair Member of Pickle IT - Gadget Repair
Business
2 Members
14 Guides authored
One Comment
This guide has nothing to do with what its title says - fan replacement.
Obsy - Reply
Past 24 Hours: 23
Past 7 Days: 118
Past 30 Days: 188
All Time: 701
