LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement
Views: 9.5K
View statistics:
Past 24 Hours:
9
Past 7 Days:
37
Past 30 Days:
141
All Time:
9,477
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Have you noticed that the water filter light on your LG LMSW27626S French 4 Door Refrigerator is flashing? Does the water or ice dispensed from the refrigerator no longer seem fresh? If you answered “yes” to either of those questions, it’s time to use this guide to change the water filter.
Water filters help to purify tap water by removing contaminants. They also help to improve the smell and taste of the water and ice dispensed from the refrigerator. The water filter should be replaced about every six months, depending on how much or little you use the water and ice dispenser.
Before beginning, be sure to remove any objects surrounding the water filter housing to allow for easy access.
The following instructions will guide you in replacing your water filter.
Parts
    1. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement, Filter: step 1, image 1 of 1
      • Find a replacement water filter based on the model number for your fridge.
      • You can also bring your old water filter to a store to get a suitable replacement that way.
      Ask FixBot
    2. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: step 2, image 1 of 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: step 2, image 2 of 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: step 2, image 3 of 3
      • For the best result, it's best to buy the original filter that was made for the fridge as opposed to an aftermarket water filter.
      • Remove the water filter from the box .
      • Remove the cap from the water filter.
      Ask FixBot
    3. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: step 3, image 1 of 2 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: step 3, image 2 of 2
      • Open the water filter bay in the top left corner of the fridge.
      Ask FixBot
    4. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: step 4, image 1 of 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: step 4, image 2 of 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: step 4, image 3 of 3
      • Remove the existing water filter inside. Or, if your fridge doesn't yet have a water filter, remove the green cap instead.
      Ask FixBot
    5. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: step 5, image 1 of 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: step 5, image 2 of 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: step 5, image 3 of 3
      • Angle the receiver in the fridge downward so that the filter is easy to plug in.
      • Firmly press the water filter into the receiver until it is snug and attached.
      • If the water filter falls out once you let go, you simply need to press harder into the receiver.
      Ask FixBot
    6. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: step 6, image 1 of 2 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: step 6, image 2 of 2
      • Shut the water filter cover.
      Ask FixBot
    7. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: step 7, image 1 of 1
      • Purge the system by dispensing water for about 2-3 minutes, or until you have cycled through approximately 64 ounces.
      • Your water should now be clean and crystal clear!
      Ask FixBot
Finish Line
Luc Charles
154 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 37
Past 30 Days: 141
All Time: 9,477
