PlayStation Move Battery Replacement
  1. PlayStation Move  Battery Replacement, Battery: step 1, image 1 of 3 PlayStation Move  Battery Replacement, Battery: step 1, image 2 of 3 PlayStation Move  Battery Replacement, Battery: step 1, image 3 of 3
    • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
  2. PlayStation Move  Battery Replacement: step 2, image 1 of 2 PlayStation Move  Battery Replacement: step 2, image 2 of 2
    • Insert the plastic opening tool at the indent.
    • Gently use a forward and backward motion to safely pop open the cover.
    • Using your hands to further pull it apart.
  3. PlayStation Move  Battery Replacement: step 3, image 1 of 2 PlayStation Move  Battery Replacement: step 3, image 2 of 2
    • Once the device is opened, lift the battery out of the black plastic holder.
    • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
  4. PlayStation Move  Battery Replacement: step 4, image 1 of 3 PlayStation Move  Battery Replacement: step 4, image 2 of 3 PlayStation Move  Battery Replacement: step 4, image 3 of 3
    • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
    • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
  5. PlayStation Move  Battery Replacement: step 5, image 1 of 2 PlayStation Move  Battery Replacement: step 5, image 2 of 2
    • Gently pull out the small grey cylindrical piece (vibrator).
    • Removing this piece makes it easier to access the wire connection of the battery and remove it.
  6. PlayStation Move  Battery Replacement: step 6, image 1 of 2 PlayStation Move  Battery Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
  7. PlayStation Move  Battery Replacement: step 7, image 1 of 3 PlayStation Move  Battery Replacement: step 7, image 2 of 3 PlayStation Move  Battery Replacement: step 7, image 3 of 3
    • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
    • Remove by squeezing the inner plastic frame, lift and pull it towards you.
    • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
  8. PlayStation Move  Battery Replacement: step 8, image 1 of 2 PlayStation Move  Battery Replacement: step 8, image 2 of 2
    • Gently pull on the white piece connecting the battery and the connector.
11 other people completed this guide.
Jenelle Mohammed
253 Reputation
1 Guide authored
USF Tampa, Team 3-3, Passmore Fall 2016 Member of USF Tampa, Team 3-3, Passmore Fall 2016
USFT-PASSMORE-F16S3G3
4 Members
10 Guides authored
5 Guide Comments
When putting the plastic battery rig back in on my second time doing this, I bent one of the little plastic pins that fits into a hole in the PCB. Definitely want to be careful with that. To make it a bit easier, I unscrewed the bottom port PCB part of the way so I could take the bottom plastic housing and put the plastic battery rig in straight. It made it a lot easier.
Burke Cates - Reply
No need to take out the motor, just use sharp tweezers and grab the connector (NOT the wires) and with small wiggling pull it out. Worked for mine.
crus - Reply
Worked great! Thanks for this. I did not need to take out the black battery / motor piece. Tweezers worked great to remove and install the battery cable
Harry Skigis - Reply
Any recommended online / physical store to buy new batteries for this because ifixit doesn’t have them?
[deleted] - Reply
Je suis pas capable de coupler les manettes et quand j essaie de l ouvrir la lumière ne reste pas allumée. Sa se peut tu que les batteries sont finis. Je viens de l acheter usager
Rachelle Tremblay - Reply
Past 24 Hours: 6
Past 7 Days: 41
Past 30 Days: 152
All Time: 16,381
