PlayStation One Lower Case Replacement
  1. PlayStation One Lower Case Replacement, Upper Case: step 1, image 1 of 1
    • Remove all cables plugged into the PlayStation.
  2. PlayStation One Lower Case Replacement: step 2, image 1 of 2 PlayStation One Lower Case Replacement: step 2, image 2 of 2
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. PlayStation One Lower Case Replacement: step 3, image 1 of 1
    • Flip the PlayStation back.
    • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
  4. PlayStation One Lower Case Replacement: step 4, image 1 of 2 PlayStation One Lower Case Replacement: step 4, image 2 of 2
    • Lift up and remove the upper case.
  5. PlayStation One Lower Case Replacement, Laser Assembly: step 5, image 1 of 3 PlayStation One Lower Case Replacement, Laser Assembly: step 5, image 2 of 3 PlayStation One Lower Case Replacement, Laser Assembly: step 5, image 3 of 3
    • Disconnect the cables from the PSone’s board.
    • Take extreme care when disconnecting the ribbon cable from motherboard. You risk damaging the cable if you’re not careful.
  6. PlayStation One Lower Case Replacement, Mother Board: step 6, image 1 of 2 PlayStation One Lower Case Replacement, Mother Board: step 6, image 2 of 2
    • remove the metal plate
  7. PlayStation One Lower Case Replacement: step 7, image 1 of 3 PlayStation One Lower Case Replacement: step 7, image 2 of 3 PlayStation One Lower Case Replacement: step 7, image 3 of 3
    • remove the mother board by lifting the back.
    • if you're having a hard time removing it, use your nail and lift the second controller port.
  8. PlayStation One Lower Case Replacement, Lower Case: step 8, image 1 of 2 PlayStation One Lower Case Replacement, Lower Case: step 8, image 2 of 2
    • Remove the metal case.
5 other people completed this guide.
Marjorie
2,345 Reputation
11 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 69
All Time: 5,072
