Introduction
This guide shows how to remove and replace the right grip shell on your PlayStation Portal.
Before you begin repairs, power off your PlayStation Portal and unplug any cables.
Rest a finger over the L1 bumper to prevent it from flying off when you pry.
Insert the flat end of a spudger between the top edge of the bumper and the white shell.
Pry up to unclip the bumper.
Slide the spudger along the seam to release any remaining clips.
Align the bumper into its slot.
Use a finger to press the bumper down firmly until it clicks into place.
Insert the tip of an opening pick underneath the left joystick trim strip, where it wraps below the grip.
Twist the opening pick to release the bottom clip.
Repeat the procedure to unclip and remove the right joystick trim strip.
Use your fingers to align and clip the top edge in place.
Firmly press along the remaining edges to clip the strip in place.
Use a Phillips screwdriver to remove the two 6.5 mm‑long screws at the bottom tips of each grip.
Push the flat edge of a spudger into the back shell's left, inner seam.
Keep the spudger inserted in the seam.
Align the corners near the trigger buttons first.
Firmly press around the entire perimeter to clip the shell back in place.
Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the right grip shell to the Portal.
Insert the flat edge of a spudger underneath the inner edge of the grip shell, near the vibration motor.
Twist the spudger along the edge to unclip the bottom portion of the grip shell.
Remove the right grip shell.
Use your fingers to peel the gray button cover away from the grip shell and remove it.
Use the point of a spudger to pry up the button gasket around the button cutouts.
Remove the button gasket.
Use the point of a spudger to pry up the menu button from its attachment point.
Remove the menu button.
