PlayStation VR Band Adjuster Replacement
  1. PlayStation VR Band Adjuster Replacement, Band Adjuster: step 1, image 1 of 3 PlayStation VR Band Adjuster Replacement, Band Adjuster: step 1, image 2 of 3 PlayStation VR Band Adjuster Replacement, Band Adjuster: step 1, image 3 of 3
    • Use your hands to remove the foam piece in the headband.
    • Use the iFixIt Opening Tool to pry the top and bottom trim pieces off of the rear band assembly.
  2. PlayStation VR Band Adjuster Replacement: step 2, image 1 of 1
    • Remove a total of four 5 mm screws from inside the left and right sides of the headband using a Phillips #00 screwdriver.
  3. PlayStation VR Band Adjuster Replacement: step 3, image 1 of 2 PlayStation VR Band Adjuster Replacement: step 3, image 2 of 2
    • Remove three silver 5 mm screws that are securing the rear white cover of the band using a Phillips #00 screwdriver.
  4. PlayStation VR Band Adjuster Replacement: step 4, image 1 of 3 PlayStation VR Band Adjuster Replacement: step 4, image 2 of 3 PlayStation VR Band Adjuster Replacement: step 4, image 3 of 3
    • Remove the 6 mm screw from the retainer securing wires to the rear band assembly using a Phillips #00 screwdriver.
    • Use a spudger to flip up the retaining flap connected to the rear LEDs.
  5. PlayStation VR Band Adjuster Replacement: step 5, image 1 of 1
    • Remove the single 5 mm screw from the center of the headband adjuster using a Phillips #00 screwdriver.
  6. PlayStation VR Band Adjuster Replacement: step 6, image 1 of 1
    • Gently pry the adjuster assembly away from the rear headband using an opening tool.
  7. PlayStation VR Band Adjuster Replacement: step 7, image 1 of 3 PlayStation VR Band Adjuster Replacement: step 7, image 2 of 3 PlayStation VR Band Adjuster Replacement: step 7, image 3 of 3
    • Disassemble the adjuster assembly spring, small gear, large gear, and bracket in order to replace the broken component.
0 Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 67
All Time: 2,458
