PlayStation VR Rear LED Tracker Board Replacement
  1. PlayStation VR Rear LED Tracker Board Replacement, Band Adjuster: step 1, image 1 of 3 PlayStation VR Rear LED Tracker Board Replacement, Band Adjuster: step 1, image 2 of 3 PlayStation VR Rear LED Tracker Board Replacement, Band Adjuster: step 1, image 3 of 3
    • Use your hands to remove the foam piece in the headband.
    • Use the iFixIt Opening Tool to pry the top and bottom trim pieces off of the rear band assembly.
  2. PlayStation VR Rear LED Tracker Board Replacement: step 2, image 1 of 1
    • Remove a total of four 5 mm screws from inside the left and right sides of the headband using a Phillips #00 screwdriver.
  3. PlayStation VR Rear LED Tracker Board Replacement: step 3, image 1 of 2 PlayStation VR Rear LED Tracker Board Replacement: step 3, image 2 of 2
    • Remove three silver 5 mm screws that are securing the rear white cover of the band using a Phillips #00 screwdriver.
  4. PlayStation VR Rear LED Tracker Board Replacement: step 4, image 1 of 3 PlayStation VR Rear LED Tracker Board Replacement: step 4, image 2 of 3 PlayStation VR Rear LED Tracker Board Replacement: step 4, image 3 of 3
    • Remove the 6 mm screw from the retainer securing wires to the rear band assembly using a Phillips #00 screwdriver.
    • Use a spudger to flip up the retaining flap connected to the rear LEDs.
  5. PlayStation VR Rear LED Tracker Board Replacement: step 5, image 1 of 1
    • Remove the single 5 mm screw from the center of the headband adjuster using a Phillips #00 screwdriver.
  6. PlayStation VR Rear LED Tracker Board Replacement: step 6, image 1 of 1
    • Gently pry the adjuster assembly away from the rear headband using an opening tool.
  7. PlayStation VR Rear LED Tracker Board Replacement: step 7, image 1 of 3 PlayStation VR Rear LED Tracker Board Replacement: step 7, image 2 of 3 PlayStation VR Rear LED Tracker Board Replacement: step 7, image 3 of 3
    • Disassemble the adjuster assembly spring, small gear, large gear, and bracket in order to replace the broken component.
  8. PlayStation VR Rear LED Tracker Board Replacement, Rear LED Tracker Board: step 8, image 1 of 3 PlayStation VR Rear LED Tracker Board Replacement, Rear LED Tracker Board: step 8, image 2 of 3 PlayStation VR Rear LED Tracker Board Replacement, Rear LED Tracker Board: step 8, image 3 of 3
    • Once the rear headband is removed, both rear LED tracker boards can be identified as the white components labelled 'L' and 'R' on the rear of the band.
    • Remove the single 5 mm screw from each of the LED tracker boards using a Phillips #00 screwdriver.
    • Gently pull up and slide each tracker board outward, away from the center of the band, in order to free it from the rear headband shell.
  9. PlayStation VR Rear LED Tracker Board Replacement: step 9, image 1 of 3 PlayStation VR Rear LED Tracker Board Replacement: step 9, image 2 of 3 PlayStation VR Rear LED Tracker Board Replacement: step 9, image 3 of 3
    • The tracker board assembly is comprised of two shell halves.
    • Gently pry on the black tabs on the outward edge of the shell to free the two halves from each other.
    • Then gently pry outward on the internal tracker board to free each one from the opaque lens.
  10. PlayStation VR Rear LED Tracker Board Replacement: step 10, image 1 of 2 PlayStation VR Rear LED Tracker Board Replacement: step 10, image 2 of 2
    • Use a soldering iron in order to remove the three wires (black, white, red) from the faulty tracker board.
One Comment
Salve grazie per la splendida guida , devo sostituire un tracker led LRR-01 ma non riesco a trovare un venditore online, puoi aiutarmi grazie
Alexjei Rais - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 16
All Time: 561
