PlayStation Vita Speakers Replacement
  1. PlayStation Vita Speakers Replacement, Case Separation: step 1, image 1 of 2 PlayStation Vita Speakers Replacement, Case Separation: step 1, image 2 of 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Speakers Replacement: step 2, image 1 of 3 PlayStation Vita Speakers Replacement: step 2, image 2 of 3 PlayStation Vita Speakers Replacement: step 2, image 3 of 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Speakers Replacement: step 3, image 1 of 2 PlayStation Vita Speakers Replacement: step 3, image 2 of 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Speakers Replacement: step 4, image 1 of 3 PlayStation Vita Speakers Replacement: step 4, image 2 of 3 PlayStation Vita Speakers Replacement: step 4, image 3 of 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Speakers Replacement: step 5, image 1 of 2 PlayStation Vita Speakers Replacement: step 5, image 2 of 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Speakers Replacement: step 6, image 1 of 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Speakers Replacement: step 7, image 1 of 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Speakers Replacement: step 8, image 1 of 1
    • Separate the front and rear cases.
  9. PlayStation Vita Speakers Replacement, Speakers: step 9, image 1 of 2 PlayStation Vita Speakers Replacement, Speakers: step 9, image 2 of 2
    • Gently insert a spudger along the side of the speaker on the back casing assembly. Pry the speaker off the casing and remove it.
    • The speaker is adhered to the casing with light tape, which may give the speaker light resistance.
3 other people completed this guide.
Brittany McCrigler
89,113 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
2 Comments
My Ps vita is still not playing sound with the volume all the way up. Think this could be electrical?
Sarah - Reply
my ps vita 3G model get washed, i dismantle the console and both speakers to let it dry. 1 month later my vita woke up but now the speakers sound bad, is there a way to fix them?
Luis Hernández - Reply
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 127
All Time: 12,495
