Playstation Classic Motherboard Replacement
Maxwell Webb
Maxwell Webb and 7 other contributors
Last updated on August 20, 2024
15 minutes
Easy
Featured Student Guide
Introduction
Go to step 1
This guide will walk you through how to replace a faulty motherboard in the Sony Playstation Classic. Make sure to be gentle when handling your motherboard.
Tools
  1. Playstation Classic Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Flip the console so its back is facing up.
  2. Playstation Classic Motherboard Replacement: step 2, image 1 of 1
    • Remove the five 3mm screws using the Phillips #00 screwdriver.
    • Make sure to keep your screws together in a secure location to avoid misplacement.
  3. Playstation Classic Motherboard Replacement: step 3, image 1 of 3 Playstation Classic Motherboard Replacement: step 3, image 2 of 3 Playstation Classic Motherboard Replacement: step 3, image 3 of 3
    • Remove the back plate from the rest of the console using your hands or the Jimmy tool.
  4. Playstation Classic Motherboard Replacement: step 4, image 1 of 1
    • Unscrew the motherboard's five 3mm screws with the Phillips #00 screwdriver.
    • Be careful not to apply too much force. The motherboard is flimsy and easy to break.
    • Keep track of your screws once they are removed.
    On this step there is actually only 4 screws. looking at this picture the top middle circled hole is for the screw for the bottom cover.
    ty vw - Reply
  5. Playstation Classic Motherboard Replacement: step 5, image 1 of 3 Playstation Classic Motherboard Replacement: step 5, image 2 of 3 Playstation Classic Motherboard Replacement: step 5, image 3 of 3
    • Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
  6. Playstation Classic Motherboard Replacement: step 6, image 1 of 3 Playstation Classic Motherboard Replacement: step 6, image 2 of 3 Playstation Classic Motherboard Replacement: step 6, image 3 of 3
    • The motherboard is connected to its metal protective casing with sticky pads. No tools are required to remove it.
    • Pull the metal casing off the motherboard.
    • Remember to be gentle when handling the motherboard.
    Alguien sabe repara puertos USB no me reconoce nada ni los controles
    Juan Abraham Avila Yampey - Reply
    Qualcuno sa come riparare le porte USB, non riconosce nulla o i controlli
    LORENZO MANCUSI - Reply
5 other people completed this guide.
Maxwell Webb
685 Reputation
5 Guides authored
Cal Poly, Team S2-G8, Maness Spring 2019 Member of Cal Poly, Team S2-G8, Maness Spring 2019
CPSU-MANESS-S19S2G8
2 Members
23 Guides authored
2 Guide Comments
where do you get a ps1 classic mini motherboard ?
blaqdemon69 - Reply
You would probably be cannibalizing a broken PS1 Classic for its motherboard. Perhaps "Parts Only."
Matt Latsha -
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 121
All Time: 4,437
