Playstation Classic Power Button Replacement
  1. Playstation Classic Power Button Replacement, Motherboard: step 1, image 1 of 1
    • Flip the console so its back is facing up.
  2. Playstation Classic Power Button Replacement: step 2, image 1 of 1
    • Remove the five 8mm screws using the Phillips #00 screwdriver.
    • Make sure to keep your screws together in a secure location to avoid misplacement.
  3. Playstation Classic Power Button Replacement: step 3, image 1 of 3 Playstation Classic Power Button Replacement: step 3, image 2 of 3 Playstation Classic Power Button Replacement: step 3, image 3 of 3
    • Remove the back plate from the rest of the console using your hands or the Jimmy tool.
  4. Playstation Classic Power Button Replacement: step 4, image 1 of 1
    • Unscrew the motherboard's four 6mm screws with the Phillips #00 screwdriver.
    • Be careful not to apply too much force. The motherboard is flimsy and easy to break.
    • Keep track of your screws once they are removed.
  5. Playstation Classic Power Button Replacement: step 5, image 1 of 3 Playstation Classic Power Button Replacement: step 5, image 2 of 3 Playstation Classic Power Button Replacement: step 5, image 3 of 3
    • Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
  6. Playstation Classic Power Button Replacement: step 6, image 1 of 3 Playstation Classic Power Button Replacement: step 6, image 2 of 3 Playstation Classic Power Button Replacement: step 6, image 3 of 3
    • The motherboard is connected to its metal protective casing with sticky pads. No tools are required to remove it.
    • Pull the metal casing off the motherboard.
    • Remember to be gentle when handling the motherboard.
  7. Playstation Classic Power Button Replacement, Power Button: step 7, image 1 of 3 Playstation Classic Power Button Replacement, Power Button: step 7, image 2 of 3 Playstation Classic Power Button Replacement, Power Button: step 7, image 3 of 3
    • After removing the motherboard, position the casing so that the back of the power button is visible.
    • Use a spudger to apply pressure inward on the three plastic clips.
    • This will loosen the button enough to remove it from its position.
  8. Playstation Classic Power Button Replacement: step 8, image 1 of 3 Playstation Classic Power Button Replacement: step 8, image 2 of 3 Playstation Classic Power Button Replacement: step 8, image 3 of 3
    • Flip the casing to its front and remove the loose button with your hand.
    • Leave the spring in its original position.
To reassemble your device, follow these instructions in reverse order.
Maxwell Webb
703 Reputation
5 Guides authored
Cal Poly, Team S2-G8, Maness Spring 2019 Member of Cal Poly, Team S2-G8, Maness Spring 2019
CPSU-MANESS-S19S2G8
2 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 54
All Time: 3,335
