Poin2 Chromebook 11 Touchpad Replacement
  1. Poin2 Chromebook 11 Touchpad Replacement, Battery: step 1, image 1 of 2 Poin2 Chromebook 11 Touchpad Replacement, Battery: step 1, image 2 of 2
    • Power down the Poin2 Chromebook 11 and disconnect the power adapter.
    • Close the Chromebook and position it with the base facing up.
    • Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
    • Poin2 Chromebook 11 does not have screws under its rubber feet at the base.
  2. Poin2 Chromebook 11 Touchpad Replacement: step 2, image 1 of 3 Poin2 Chromebook 11 Touchpad Replacement: step 2, image 2 of 3 Poin2 Chromebook 11 Touchpad Replacement: step 2, image 3 of 3
    • Insert a 1cm-wide plastic opening tool between the base and top frame.
    • Applying pressure up and down with the tool may be necessary. When you hear a "click," this indicates the separation of the frame.
    • Pry (up and down) around the entire border of the Chromebook to separate.
    • Use your hands to gently lift the base away from the frame.
  3. Poin2 Chromebook 11 Touchpad Replacement: step 3, image 1 of 3 Poin2 Chromebook 11 Touchpad Replacement: step 3, image 2 of 3 Poin2 Chromebook 11 Touchpad Replacement: step 3, image 3 of 3
    • Disconnect the white 8-wire battery connector from the motherboard using a spudger to push the two L-shaped clips out of the port.
    • The connector is a tight fit and requires careful pressure for release.
  4. Poin2 Chromebook 11 Touchpad Replacement: step 4, image 1 of 2 Poin2 Chromebook 11 Touchpad Replacement: step 4, image 2 of 2
    • Remove the six 4mm screws using a Phillips #0 screwdriver.
  5. Poin2 Chromebook 11 Touchpad Replacement: step 5, image 1 of 1
    • Lift the battery from the frame.
  6. Poin2 Chromebook 11 Touchpad Replacement, Touchpad: step 6, image 1 of 3 Poin2 Chromebook 11 Touchpad Replacement, Touchpad: step 6, image 2 of 3 Poin2 Chromebook 11 Touchpad Replacement, Touchpad: step 6, image 3 of 3
    • Locate the ZIF connector on the touchpad's circuit board.
    • Use the tip of the spudger to flip the locking flap to the perpendicular position and pull the cable out.
    • See also the Connectors Guide for detailed instructions, as well as iFixit's cable connectors guide.
  7. Poin2 Chromebook 11 Touchpad Replacement: step 7, image 1 of 3 Poin2 Chromebook 11 Touchpad Replacement: step 7, image 2 of 3 Poin2 Chromebook 11 Touchpad Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the black tape holding down the touchpad.
    • Remove the strips of gold electrostatic tape also holding down the touchpad.
    • Use a metal spudger or tweezers to help pry up the corners of the tape, but be careful not to use to much force or risk damaging the heat sink.
    • Applying new tape is suggested, but the tape can be re-used.
  8. Poin2 Chromebook 11 Touchpad Replacement: step 8, image 1 of 2 Poin2 Chromebook 11 Touchpad Replacement: step 8, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the two 2 mm screws securing the metal plate that holds the touchpad in place
  9. Poin2 Chromebook 11 Touchpad Replacement: step 9, image 1 of 1
    • Slide the touchpad plate in the direction of the screw holes to free the plates bottom edge from under the plastic frame.
  10. Poin2 Chromebook 11 Touchpad Replacement: step 10, image 1 of 1
    • Remove touchpad from the opposite side of the metal plate.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 273
