Pokémon™ GO Plus+ Vibration Motor Disable
  1. Pokémon™ GO Plus+ Vibration Motor Disable, Remove the two screws from the bottom: step 1, image 1 of 1
    • Flanking both sides of the charging port are J00 Screws. Remove these.
    • These screws go into plastic, so when re-assembling the device, be very careful not to over tighten them.
    • These two screws are identical to each other, but differ from the screws within the device, keep them separate from any screws you remove from within the device.
  2. Pokémon™ GO Plus+ Vibration Motor Disable, Remove Faceplace: step 2, image 1 of 2 Pokémon™ GO Plus+ Vibration Motor Disable, Remove Faceplace: step 2, image 2 of 2
    • When looking at the front of the device, with the charging point at the bottom the device has a hinge clip and wires on the top right.
    • While opening, be extremely careful not to damage the fragile cables and connection between the main body and the faceplate.
    • With a fingernail or some kind of slim pry tool, gently lift from the bottom left corner.
    • There is adhesive that is holding the faceplate on, If you have difficulty pulling it off, use a plastic spudger by inserting it in on the bottom left then slowly hinge the device open while applying pressure to the adhesive pad to loosen it.
  3. Pokémon™ GO Plus+ Vibration Motor Disable, Cut the motor wire: step 3, image 1 of 1
    • Cut the black wire connected to the motor. This vibration motor is soldered directly to the main board, and there is no way to disconnect it without severing the cable.
    • This is a one way change. after cutting this cable you cannot re-connect it to get vibration back without much more difficult soldering work.
    • As an alternative to fully disabling the motor by disconnecting it, you can take a metal file to the counterweight on the motor. Removing excess mass from this weight will drastically soften the vibration
    • Using a small bit of electrical tape or glue, cover the ends of the wire you snipped so they don't short out on anything else inside the device.
David
576 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 9
Past 7 Days: 86
Past 30 Days: 331
All Time: 1,555
