Polar M400 Watch Battery Replacement
  1. Polar M400 Watch Battery Replacement, Wrist Strap: step 1, image 1 of 1
    • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
  2. Polar M400 Watch Battery Replacement: step 2, image 1 of 2 Polar M400 Watch Battery Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Apply an upward pressure to the holes until the locking pins release.
    • Use precision tweezers to remove the pins that connect the face with the strap.
  3. Polar M400 Watch Battery Replacement: step 3, image 1 of 1
    • Once the pins are released, the old wrist strap should snap off.
    • Simply lock the new wrist strap into place.
  4. Polar M400 Watch Battery Replacement, Battery: step 4, image 1 of 1
    • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
  5. Polar M400 Watch Battery Replacement: step 5, image 1 of 2 Polar M400 Watch Battery Replacement: step 5, image 2 of 2
    • Gently remove the backing from the watch.
  6. Polar M400 Watch Battery Replacement: step 6, image 1 of 2 Polar M400 Watch Battery Replacement: step 6, image 2 of 2
    Buy
    • Use tweezers to gently pry the golden sensor away from the battery.
    • Remove battery using the plastic opening tools.
15 other people completed this guide.
Nicholas Sanders
513 Reputation
2 Guides authored
25 Comments
Hello, thanks for the details !
The most tricky part: find the right spare part. I can’t find a replacement battery that could fit the original dimensions with reasonnable capacity.
Do you have any lead?
Vincent - Reply
In case if anyone is still looking for the spare part I have just replaced my M400 battery with this one: https://www.aliexpress.com/item/10050045...
Replacement instructions were detailed enough to get my watch to work again.
Roman -
Bonjour
Pourriez-vous m’indiquer ou je peux acheter une batterie compatible ou originale
Merci à vous
ducellier - Reply
where can i buy a batery for my polar m400? Link please. Thanks
lsmi_21 - Reply
Once the battery is changed, the M400 does not work. Do you have to press any combination of keys?
lojobis - Reply
Past 24 Hours: 7
Past 7 Days: 57
Past 30 Days: 237
All Time: 30,023
