Polaroid I-2 Back Cover Removal with Film Door Replacement
Alex Diaz-Kokaisl
Alex Diaz-Kokaisl and 2 other contributors
Last updated on May 7, 2024
45 minutes - 1 hour
Difficult
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
Introduction
Go to step 1
Prereq to remove the back cover with the film door still attached. Used for the display and the back cover itself.
Tools
Show more…
  1. Polaroid I-2 Back Cover Removal with Film Door Replacement, Safety information: step 1, image 1 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Safety information: step 1, image 2 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Safety information: step 1, image 3 of 3
    • If you have any film left, take some photos and remove the cartridge! Disassembly will expose the film and damage it.
    • Before you begin:
    • Power down and unplug your camera.
    • Put on the lens cap to avoid scratching your lens during disassembly.
  2. Polaroid I-2 Back Cover Removal with Film Door Replacement, Open the film door: step 2, image 1 of 2 Polaroid I-2 Back Cover Removal with Film Door Replacement, Open the film door: step 2, image 2 of 2
    • In the following steps, "left" and "right" are written from the perspective of using the camera—or when the lens is facing away from you.
    • Use the latch on the left side of the camera to open the film door.
  3. Polaroid I-2 Back Cover Removal with Film Door Replacement, Insert a blocker: step 3, image 1 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Insert a blocker: step 3, image 2 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Insert a blocker: step 3, image 3 of 3
    • Fold a piece of cloth or napkin (or the included bag) into a small square.
    • Insert the cloth into the film compartment far enough to block the film door from closing during disassembly.
  4. Polaroid I-2 Back Cover Removal with Film Door Replacement, Flip the camera over: step 4, image 1 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Flip the camera over: step 4, image 2 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Flip the camera over: step 4, image 3 of 3
    • Flip the camera over, making sure the cloth stays lodged in the film compartment.
  5. Polaroid I-2 Back Cover Removal with Film Door Replacement, Unfasten the bottom cover: step 5, image 1 of 1
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the bottom cover.
  6. Polaroid I-2 Back Cover Removal with Film Door Replacement, Unclip the bottom cover: step 6, image 1 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Unclip the bottom cover: step 6, image 2 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Unclip the bottom cover: step 6, image 3 of 3
    • Insert the tip of an opening pick under the top left corner of the bottom cover, near the slider button.
    • Tilt the pick up and push to position the pick between the bottom and front covers.
  7. Polaroid I-2 Back Cover Removal with Film Door Replacement: step 7, image 1 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement: step 7, image 2 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement: step 7, image 3 of 3
    • Slide the opening pick toward the rear of the camera to release the clips along the left edge.
    • Leave the opening pick at the bottom left corner to prevent the clips from resecuring.
  8. Polaroid I-2 Back Cover Removal with Film Door Replacement: step 8, image 1 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement: step 8, image 2 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement: step 8, image 3 of 3
    • Insert the tip of a second opening pick under the top right corner of the bottom cover.
  9. Polaroid I-2 Back Cover Removal with Film Door Replacement: step 9, image 1 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement: step 9, image 2 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement: step 9, image 3 of 3
    • Slide the opening pick toward the rear of the camera to release the clips along the right edge.
  10. Polaroid I-2 Back Cover Removal with Film Door Replacement, Remove the bottom cover: step 10, image 1 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Remove the bottom cover: step 10, image 2 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Remove the bottom cover: step 10, image 3 of 3
    • At this point, the bottom cover clips should be released. If not, slide an opening pick along the perimeter of the back cover to release any remaining clips.
    • Tilt the back of the bottom cover upward and pull it away from the camera, making sure to thread the film door lever from its recess.
    • Remove the back cover.
    • During reassembly, insert the film door lever into its recess before aligning the bottom cover and pressing it into place to secure its clips.
  11. Polaroid I-2 Back Cover Removal with Film Door Replacement, Remove the blocker: step 11, image 1 of 1
    • At this point, you can remove the blocker from the film compartment.
  12. Polaroid I-2 Back Cover Removal with Film Door Replacement, Unfasten the back cover: step 12, image 1 of 1
    • Use a Phillips screwdriver to remove the two 3.9 mm-long screws securing the back cover.
  13. Polaroid I-2 Back Cover Removal with Film Door Replacement, Separate the alignment pegs: step 13, image 1 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Separate the alignment pegs: step 13, image 2 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Separate the alignment pegs: step 13, image 3 of 3
    • There are two alignment pegs along the bottom edge of the back cover.
    • Insert a spudger between the frame and the alignment hole on the back cover.
    • Twist the spudger to lift the back cover off of the alignment peg.
    • Repeat for the second alignment peg.
  14. Polaroid I-2 Back Cover Removal with Film Door Replacement, Disassembly information: step 14, image 1 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Disassembly information: step 14, image 2 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Disassembly information: step 14, image 3 of 3
    • There are eight large clips that secure the back cover. The next four steps show how to release them.
    • These clips are very strong and require significant force to release.
    • The procedure to release the clips is tricky and will require time and patience to perform correctly.
  15. Polaroid I-2 Back Cover Removal with Film Door Replacement, Unclip the back cover: step 15, image 1 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Unclip the back cover: step 15, image 2 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Unclip the back cover: step 15, image 3 of 3
    • Releasing the clips requires getting a tool between the covered "thin" edge of the front cover and the clips themselves.
    • Angle an opening pick upward and insert it at the gap where the bottom right corner of the back cover meets the triangular tip of the front cover’s right edge.
    • Push the pick up to get it above the overhanging lip in the back cover.
    • You'll see the plastic warp a little. This is normal.
    • While pushing upward, slowly rotate the pick towards the left edge of the camera until it's under the front cover.
    • The pick can slip out easily, so this may take a few tries.
  16. Polaroid I-2 Back Cover Removal with Film Door Replacement: step 16, image 1 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement: step 16, image 2 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement: step 16, image 3 of 3
    • While pushing the pick downward, slide it all the way up the right edge to release the clips.
    • Keep the pick as upright as possible while sliding to avoid hitting the clips.
    • The plastic in the lip of the back cover will warp. This is normal.
    • Leave the pick at the top corner before continuing to prevent the clips from resecuring.
  17. Polaroid I-2 Back Cover Removal with Film Door Replacement: step 17, image 1 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement: step 17, image 2 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement: step 17, image 3 of 3
    • Angle a second opening pick upward and insert it at the gap where the bottom left corner of the back cover meets the triangular tip of the front cover’s left edge.
    • While pushing upward, slowly rotate the pick towards the right edge of the camera until it's under the front cover.
  18. Polaroid I-2 Back Cover Removal with Film Door Replacement: step 18, image 1 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement: step 18, image 2 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement: step 18, image 3 of 3
    • While pushing the pick downward, slide it all the way up the left edge to release the remaining clips.
  19. Polaroid I-2 Back Cover Removal with Film Door Replacement, Reposition the back cover: step 19, image 1 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Reposition the back cover: step 19, image 2 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Reposition the back cover: step 19, image 3 of 3
    • Don't try to pull the back cover off just yet, as it's still connected by a cable.
    • At this point, the back cover should feel loose. If any parts still feel connected, repeat the last four steps until all the clips release.
    • Pull the back cover off the camera and rotate it over the right edge to expose the flex cable.
    • During reassembly, make sure the the flex cable isn't caught between the covers before re-engaging the clips.
  20. Polaroid I-2 Back Cover Removal with Film Door Replacement, Remove the tape: step 20, image 1 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Remove the tape: step 20, image 2 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement, Remove the tape: step 20, image 3 of 3
    Tool used on this step:
    • Use tweezers to peel off the tape covering the interconnect cable ZIF connector on the control board.
    • Set the tape aside. You'll reuse it during reassembly.
  21. Polaroid I-2 Back Cover Removal with Film Door Replacement, Disconnect the control board: step 21, image 1 of 2 Polaroid I-2 Back Cover Removal with Film Door Replacement, Disconnect the control board: step 21, image 2 of 2
    • Use the flat end of a spudger to lift up the locking flap on the control board ZIF connector.
  22. Polaroid I-2 Back Cover Removal with Film Door Replacement: step 22, image 1 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement: step 22, image 2 of 3 Polaroid I-2 Back Cover Removal with Film Door Replacement: step 22, image 3 of 3
    • Use tweezers to pull the interconnect cable out of its slot in the control board.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Polaroid I-2 Answers community for help.
Alex Diaz-Kokaisl
163,222 Reputation
769 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,537 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 217
