Polaroid I-2 Bottom Cover Replacement
  1. Polaroid I-2 Bottom Cover Replacement, Safety information: step 1, image 1 of 3 Polaroid I-2 Bottom Cover Replacement, Safety information: step 1, image 2 of 3 Polaroid I-2 Bottom Cover Replacement, Safety information: step 1, image 3 of 3
    • If you have any film left, take some photos and remove the cartridge! Disassembly will expose the film and damage it.
    • Before you begin:
    • Power down and unplug your camera.
    • Put on the lens cap to avoid scratching your lens during disassembly.
  2. Polaroid I-2 Bottom Cover Replacement, Open the film door: step 2, image 1 of 2 Polaroid I-2 Bottom Cover Replacement, Open the film door: step 2, image 2 of 2
    • In the following steps, "left" and "right" are written from the perspective of using the camera—or when the lens is facing away from you.
    • Use the latch on the left side of the camera to open the film door.
  3. Polaroid I-2 Bottom Cover Replacement, Insert a blocker: step 3, image 1 of 3 Polaroid I-2 Bottom Cover Replacement, Insert a blocker: step 3, image 2 of 3 Polaroid I-2 Bottom Cover Replacement, Insert a blocker: step 3, image 3 of 3
    • Fold a piece of cloth or napkin (or the included bag) into a small square.
    • Insert the cloth into the film compartment far enough to block the film door from closing during disassembly.
  4. Polaroid I-2 Bottom Cover Replacement, Flip the camera over: step 4, image 1 of 3 Polaroid I-2 Bottom Cover Replacement, Flip the camera over: step 4, image 2 of 3 Polaroid I-2 Bottom Cover Replacement, Flip the camera over: step 4, image 3 of 3
    • Flip the camera over, making sure the cloth stays lodged in the film compartment.
  5. Polaroid I-2 Bottom Cover Replacement, Unfasten the bottom cover: step 5, image 1 of 1
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the bottom cover.
  6. Polaroid I-2 Bottom Cover Replacement, Unclip the bottom cover: step 6, image 1 of 3 Polaroid I-2 Bottom Cover Replacement, Unclip the bottom cover: step 6, image 2 of 3 Polaroid I-2 Bottom Cover Replacement, Unclip the bottom cover: step 6, image 3 of 3
    • Insert the tip of an opening pick under the top left corner of the bottom cover, near the slider button.
    • Tilt the pick up and push to position the pick between the bottom and front covers.
  7. Polaroid I-2 Bottom Cover Replacement: step 7, image 1 of 3 Polaroid I-2 Bottom Cover Replacement: step 7, image 2 of 3 Polaroid I-2 Bottom Cover Replacement: step 7, image 3 of 3
    • Slide the opening pick toward the rear of the camera to release the clips along the left edge.
    • Leave the opening pick at the bottom left corner to prevent the clips from resecuring.
  8. Polaroid I-2 Bottom Cover Replacement: step 8, image 1 of 3 Polaroid I-2 Bottom Cover Replacement: step 8, image 2 of 3 Polaroid I-2 Bottom Cover Replacement: step 8, image 3 of 3
    • Insert the tip of a second opening pick under the top right corner of the bottom cover.
  9. Polaroid I-2 Bottom Cover Replacement: step 9, image 1 of 3 Polaroid I-2 Bottom Cover Replacement: step 9, image 2 of 3 Polaroid I-2 Bottom Cover Replacement: step 9, image 3 of 3
    • Slide the opening pick toward the rear of the camera to release the clips along the right edge.
  10. Polaroid I-2 Bottom Cover Replacement, Remove the bottom cover: step 10, image 1 of 3 Polaroid I-2 Bottom Cover Replacement, Remove the bottom cover: step 10, image 2 of 3 Polaroid I-2 Bottom Cover Replacement, Remove the bottom cover: step 10, image 3 of 3
    • At this point, the bottom cover clips should be released. If not, slide an opening pick along the perimeter of the back cover to release any remaining clips.
    • Tilt the back of the bottom cover upward and pull it away from the camera, making sure to thread the film door lever from its recess.
    • Remove the back cover.
    • During reassembly, insert the film door lever into its recess before aligning the bottom cover and pressing it into place to secure its clips.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Polaroid I-2 Answers community for help.
Alex Diaz-Kokaisl
216,159 Reputation
1,046 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,888 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 657
