Polaroid OneStep 2 Flash Cover Replacement
  1. Polaroid OneStep 2 Flash Cover Replacement, Flash Cover: step 1, image 1 of 3 Polaroid OneStep 2 Flash Cover Replacement, Flash Cover: step 1, image 2 of 3 Polaroid OneStep 2 Flash Cover Replacement, Flash Cover: step 1, image 3 of 3
    • Unscrew the four 5mm screws on the base of the camera. Remove the two pieces of the base.
  2. Polaroid OneStep 2 Flash Cover Replacement: step 2, image 1 of 3 Polaroid OneStep 2 Flash Cover Replacement: step 2, image 2 of 3 Polaroid OneStep 2 Flash Cover Replacement: step 2, image 3 of 3
    • Unscrew the four 5mm screws on the top of the inside base piece.
    • Unscrew the two 5mm screws on the bottom of the inside base piece which is near the strap.
  3. Polaroid OneStep 2 Flash Cover Replacement: step 3, image 1 of 1
    • Remove the inside black base piece.
  4. Polaroid OneStep 2 Flash Cover Replacement: step 4, image 1 of 2 Polaroid OneStep 2 Flash Cover Replacement: step 4, image 2 of 2
    • With force separate the front white piece from the back of the camera. You will use your hands to pull it apart.
  5. Polaroid OneStep 2 Flash Cover Replacement: step 5, image 1 of 2 Polaroid OneStep 2 Flash Cover Replacement: step 5, image 2 of 2
    • Forcefully pull on the flash cover until it is removed.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 1,769
