Introduction
If you need to replace the shutter switch, use this guide to access the inside of the camera. You may need to replace the shutter switch if your shutter is not firing and your camera is not taking photos.
Remove the four 5mm screws on the base of the camera using a Phillips #0 screwdriver.
Remove the two pieces of the base.
3 other people completed this guide.
