Polaroid S10 Battery Replacement
  1. Polaroid S10 Battery Replacement, Removing the backcover: step 1, image 1 of 3 Polaroid S10 Battery Replacement, Removing the backcover: step 1, image 2 of 3 Polaroid S10 Battery Replacement, Removing the backcover: step 1, image 3 of 3
    • Place an opening pick between the volume button and the back cover.
    • More than one pick may be needed, but avoid placing more than two picks in the same space.
    • Excessive force on the pick will break the volume button.
    • Carefully remove the back cover using the metal spudger.
    • It is normal to hear a snapping noise due to the plastic tabs on the back cover.
  2. Polaroid S10 Battery Replacement, Battery: step 2, image 1 of 3 Polaroid S10 Battery Replacement, Battery: step 2, image 2 of 3 Polaroid S10 Battery Replacement, Battery: step 2, image 3 of 3
    • Use a spudger to carefully remove the tape nearest to the battery.
    • Use caution while removing tape. Too much force can damage the device.
    • Gently use the spudger to remove the battery out of place by wedging it out from the bottom.
    • Do not move the battery. Moving it could cause the cables to be ripped out.
  3. Polaroid S10 Battery Replacement, Battery Connection: step 3, image 1 of 2 Polaroid S10 Battery Replacement, Battery Connection: step 3, image 2 of 2
    • Carefully desolder the 2 wires that connect the battery to the motherboard.
    • Do not touch the soldering iron to the motherboard or the LCD screen.
Follow these instructions to reassemble your device.
James
367 Reputation
3 Guides authored
One Comment
Can't open the %#*@ thing!!!!!!!!!!
tosaguys - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 5,196
