Polaroid S10 volume button Replacement
  1. Polaroid S10 volume button Replacement, Removing the backcover: step 1, image 1 of 3 Polaroid S10 volume button Replacement, Removing the backcover: step 1, image 2 of 3 Polaroid S10 volume button Replacement, Removing the backcover: step 1, image 3 of 3
    • Place an opening pick between the volume button and the back cover.
    • More than one pick may be needed, but avoid placing more than two picks in the same space.
    • Excessive force on the pick will break the volume button.
    • Carefully remove the back cover using the metal spudger.
    • It is normal to hear a snapping noise due to the plastic tabs on the back cover.
  2. Polaroid S10 volume button Replacement, Volume and Power Button Board: step 2, image 1 of 2 Polaroid S10 volume button Replacement, Volume and Power Button Board: step 2, image 2 of 2
    • Use the spudger to remove the tape.
    • Remove the 2 J000 4 mm screws using a J000 screwdriver.
    • Carefully disconnect the connector port.
James
367 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 346
