Polaroid S7 Battery Replacement
  1. Polaroid S7 Battery Replacement, Remove the back: step 1, image 1 of 2 Polaroid S7 Battery Replacement, Remove the back: step 1, image 2 of 2
    • Insert the flat end of a soft plastic opening tool between the screen and the back cover.
    • Pry the two pieces apart.
    • Take care not to rip the ribbons that connect the screen to the back cover.
  2. Polaroid S7 Battery Replacement: step 2, image 1 of 1
    • Use a metal spudger to remove the orange sticker.
  3. Polaroid S7 Battery Replacement: step 3, image 1 of 1
    • Use the screwdriver to remove the 2 x 4 mm Phillips #00 head screws from the blue board located on the lower-right corner of the battery.
  4. Polaroid S7 Battery Replacement: step 4, image 1 of 2 Polaroid S7 Battery Replacement: step 4, image 2 of 2
    • Use the metal spudger to remove the three pieces of clear tape adhering from the battery to the blue board.
    • Pry the battery up from the right side.
  5. Polaroid S7 Battery Replacement: step 5, image 1 of 1
    • Remove the yellow plastic that covers the battery connector.
  6. Polaroid S7 Battery Replacement: step 6, image 1 of 1
    • Use a soldering iron to remove the wires connected to the battery.
Anthony Larratt
269 Reputation
1 Guide authored
USF Tampa, Team 1-2, Blackwell Winter 2015 Member of USF Tampa, Team 1-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G2
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 3,249
