Polaroid SNAP Flash Cover Replacement
  1. Polaroid SNAP Flash Cover Replacement, Polaroid SNAP Front and Back Face Plate Removal: step 1, image 1 of 1
    • Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Screw head: Phillips, Screw length: 3mm
  2. Polaroid SNAP Flash Cover Replacement: step 2, image 1 of 2 Polaroid SNAP Flash Cover Replacement: step 2, image 2 of 2
    • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
    • Then it should be easy to simply lift the rear face plate up and remove it.
  3. Polaroid SNAP Flash Cover Replacement: step 3, image 1 of 2 Polaroid SNAP Flash Cover Replacement: step 3, image 2 of 2
    • Locate and remove the four screws on the corners of the camera, they're quite small and may be difficult to remove.
    • Screw head: Philips, Screw length: 5mm
  4. Polaroid SNAP Flash Cover Replacement: step 4, image 1 of 3 Polaroid SNAP Flash Cover Replacement: step 4, image 2 of 3 Polaroid SNAP Flash Cover Replacement: step 4, image 3 of 3
    • Once the screws are removed, flip the camera over
    • Use a plastic opening tool to disengage the six clips until the front face plate can be removed safely
  5. Polaroid SNAP Flash Cover Replacement: step 5, image 1 of 1
    • The cameras innards should now be accessible to you
  6. Polaroid SNAP Flash Cover Replacement, Flash Cover: step 6, image 1 of 2 Polaroid SNAP Flash Cover Replacement, Flash Cover: step 6, image 2 of 2
    • Flip the front face-plate over, so that you’re are looking at the silver plate on the inside.
  7. Polaroid SNAP Flash Cover Replacement: step 7, image 1 of 1
    • Use a plastic opening tool and pull up on the small metal tab in the middle-left inside of the front face-plate.
  8. Polaroid SNAP Flash Cover Replacement: step 8, image 1 of 1
    • While pulling up on the metal tab with the plastic opening tool, use your thumb to gently push the metal plate slightly to the right in order to release it from the tabs holding it to the face-plate.
  9. Polaroid SNAP Flash Cover Replacement: step 9, image 1 of 1
    • Once the metal plate is released from the tabs, carefully separate it from the face-plate by pulling it outwards.
  10. Polaroid SNAP Flash Cover Replacement: step 10, image 1 of 1
    • After the metal plate is removed from the front face-plate, locate the small clear flash cover on the top right of the faceplate. The flash cover should easily pop out of place.
  11. Polaroid SNAP Flash Cover Replacement: step 11, image 1 of 1
    • Remove the flash cover and place in the new one, with the holes of the flash cover oriented in the top right and bottom left corners.
2 other people completed this guide.
Austin Broyles
249 Reputation
2 Guides authored
USF Tampa, Team 7-3, Cheng Spring 2016 Member of USF Tampa, Team 7-3, Cheng Spring 2016
USFT-CHENG-S16S7G3
4 Members
19 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 2,083
