Polaroid Z2300 Control Panel Replacement
  1. Polaroid Z2300 Control Panel Replacement, Control Panel Replacement: step 1, image 1 of 3 Polaroid Z2300 Control Panel Replacement, Control Panel Replacement: step 1, image 2 of 3 Polaroid Z2300 Control Panel Replacement, Control Panel Replacement: step 1, image 3 of 3
    • Locate and remove the two 2.5 mm long screws on the bottom of the camera.
    • Screw head: JIS J00
    • The screws are very small, be careful not to strip or lose them!
  2. Polaroid Z2300 Control Panel Replacement: step 2, image 1 of 3 Polaroid Z2300 Control Panel Replacement: step 2, image 2 of 3 Polaroid Z2300 Control Panel Replacement: step 2, image 3 of 3
    • Once the two screws are removed, flip the camera to back side up.
    • Use a plastic opening tool to disengage the outer plastic trim until it can be safely removed.
  3. Polaroid Z2300 Control Panel Replacement: step 3, image 1 of 2 Polaroid Z2300 Control Panel Replacement: step 3, image 2 of 2
    • Use a plastic opening tool to pop the control panel off, it should be easy to lift up and remove.
Bradley Marcum
217 Reputation
2 Guides authored
IUPUI, Team S2-G1, Harley Fall 2018 Member of IUPUI, Team S2-G1, Harley Fall 2018
IUPUI-HARLEY-F18S2G1
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 400
