Polk MagniFi Soundbar Internal Power Adapter Replacement
  1. Polk MagniFi Soundbar Internal Power Adapter Replacement, Internal Power Adapter: step 1, image 1 of 1
    • To begin, remove the 8 screws locating on the back of the soundbar. These can be removed with the ifixit screwdriver equipped with a Phillips' head in size J1.
    • The cover will lift up, but there will be wires underneath connected to the cover that need to be unscrewed. This will be shown in the next step.
    • The 8 screws on the back cover, as well as the screws removed in the following steps, are all the exact same length (approx. 1 centimeter). Keep track of all screws but do not worry if they become mixed up.
  2. Polk MagniFi Soundbar Internal Power Adapter Replacement: step 2, image 1 of 2 Polk MagniFi Soundbar Internal Power Adapter Replacement: step 2, image 2 of 2
    • Underneath the back cover, there will be two flat panels, each with two 1cm screws.
    • Remove the two screws using the Phillips #1 screwdriver. Once they are unscrewed, the panels will hang loose allowing unobstructed access to the motherboard.
  3. Polk MagniFi Soundbar Internal Power Adapter Replacement: step 3, image 1 of 2 Polk MagniFi Soundbar Internal Power Adapter Replacement: step 3, image 2 of 2
    • To detach the cables grab the internal power adapter in one hand and with the other grab the base of the wires and firmly pull them straight out from the device.
5 other people completed this guide.
[deleted]
671 Reputation
4 Guides authored
2 Comments
where do you get the motherboard for this soundbar?
Tim - Reply
Where do we get replacement part?
Leon Haddrell - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 26
All Time: 2,359
