Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Screw: step 1, image 1 of 3 Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Screw: step 1, image 2 of 3 Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Screw: step 1, image 3 of 3
    • Inside the base cover, locate the screw holding the antenna in place and use a Philips #00 screwdriver to remove the 6mm screw.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Foot: step 2, image 1 of 2 Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Foot: step 2, image 2 of 2
    • Grasp the plastic antenna foot and pull toward you.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna: step 3, image 1 of 2 Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna: step 3, image 2 of 2
    • Pull antenna from the top side of the phone base cover.
    • It helps if you gently wiggle the antenna back and forth to loosen the clips.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 388
