Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Power and Telephone Cords: step 1, image 1 of 3 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Power and Telephone Cords: step 1, image 2 of 3 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Power and Telephone Cords: step 1, image 3 of 3
    • To disconnect the phone cord, squeeze the tab against the connector and pull the cord away from the telephone-line-in-jack.
    • To disconnect the power cord, grasp the end and pull back and away until it is disconnected.
    • Once disconnected remove each cord from its track.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Screws to Base Plate: step 2, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the six 7mm screws from the base plate.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Remove Bottom Plate from Base: step 3, image 1 of 3 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Remove Bottom Plate from Base: step 3, image 2 of 3 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Remove Bottom Plate from Base: step 3, image 3 of 3
    • With the base turned upside down, grasp the edges of the base plate and gently lift from the rest of the base.
    • Two wires lead from the motherboard to the charger plate, so the two parts cannot be completely separated without further steps.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 390
