Pool Cue Tip Replacement
  1. Pool Cue Tip Replacement, Pool Cue Tip: step 1, image 1 of 1
    • Remove the old, worn tip using a box cutter. Make sure that the old tip is completely removed.
  2. Pool Cue Tip Replacement: step 2, image 1 of 1
    • Remove any old glue or gunk using a napkin soaked with nail polish remover.
  3. Pool Cue Tip Replacement: step 3, image 1 of 1
    • Sand down the end of the pool stick using the sand paper until the surface is flat and smooth.
  4. Pool Cue Tip Replacement: step 4, image 1 of 1
    • Use the sandpaper to file the edges and backside of the new tip.
  5. Pool Cue Tip Replacement: step 5, image 1 of 1
    • Glue the sanded side of the new side of the new tip to the end of the pool tip.
  6. Pool Cue Tip Replacement: step 6, image 1 of 1
    • Place the new tip on the end of the pool cue. Hold it firmly in place until it sticks.
  7. Pool Cue Tip Replacement: step 7, image 1 of 1
    • Congratulations! You are now ready to continue using your pool stick.
3 other people completed this guide.
Carson Myers
149 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 21
All Time: 3,575
