Pop-Up Assembly Stopper Piece Replacement
  1. Pop-Up Assembly Stopper Piece Replacement, Pop-Up Stopper Piece: step 1, image 1 of 2 Pop-Up Assembly Stopper Piece Replacement, Pop-Up Stopper Piece: step 1, image 2 of 2
    • Place bucket directly under the sink below the pop-up assembly. Excess water may leak
    • The pivot rod that is inserted within a hole in the pop-up extension bar. Move the pop-up extension bar away from the pivot rod.
  2. Pop-Up Assembly Stopper Piece Replacement: step 2, image 1 of 1
    • Disconnect the pivot rod from the center pop-up extension.
  3. Pop-Up Assembly Stopper Piece Replacement: step 3, image 1 of 2 Pop-Up Assembly Stopper Piece Replacement: step 3, image 2 of 2
    • Lift up the center pop-up rod on the faucet until it is detached. The extension rod will pull up with it.
  4. Pop-Up Assembly Stopper Piece Replacement: step 4, image 1 of 3 Pop-Up Assembly Stopper Piece Replacement: step 4, image 2 of 3 Pop-Up Assembly Stopper Piece Replacement: step 4, image 3 of 3
    • Below the sink is the pivot nut. Turn the pivot nut counterclockwise until it is completely loose and remove from the pivot rod.
  5. Pop-Up Assembly Stopper Piece Replacement: step 5, image 1 of 2 Pop-Up Assembly Stopper Piece Replacement: step 5, image 2 of 2
    • Pull the pivot rod out to expose the ball. Remove the whole pivot rod fixture.
  6. Pop-Up Assembly Stopper Piece Replacement: step 6, image 1 of 2 Pop-Up Assembly Stopper Piece Replacement: step 6, image 2 of 2
    • In the sink, the pop-up stopper will be loose.
    • Pull up on the pop-up stopper to separate it from the main pop-up assembly.
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 25
All Time: 1,507
