Portege Z830-S8302 Screen Replacement
  1. Portege Z830-S8302 Screen Replacement, Screen: step 1, image 1 of 3 Portege Z830-S8302 Screen Replacement, Screen: step 1, image 2 of 3 Portege Z830-S8302 Screen Replacement, Screen: step 1, image 3 of 3
    • Use a plastic opening tool to gently pry plastic frame from screen. Detach all housing clips around the perimeter of the screen.
  2. Portege Z830-S8302 Screen Replacement: step 2, image 1 of 2 Portege Z830-S8302 Screen Replacement: step 2, image 2 of 2
    • Remove two 3mm screws with a Phillips #000 screwdriver.
  3. Portege Z830-S8302 Screen Replacement: step 3, image 1 of 2 Portege Z830-S8302 Screen Replacement: step 3, image 2 of 2
    • Wedge a blue plastic opening tool between the screen and the frame to free the screen.
    • Do not fully remove screen as it is still attached by connector cable on bottom
  4. Portege Z830-S8302 Screen Replacement: step 4, image 1 of 2 Portege Z830-S8302 Screen Replacement: step 4, image 2 of 2
    • Disconnect the display cable with your fingers to fully remove the screen from the device.
Tanner Krygier
913 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 477
