Porter Cable 690LR Base Latch Replacement
  1. Porter Cable 690LR Base Latch Replacement, Base: step 1, image 1 of 2 Porter Cable 690LR Base Latch Replacement, Base: step 1, image 2 of 2
    • Undo the black latch located on the base of the router by pulling upwards from underneath it.
  2. Porter Cable 690LR Base Latch Replacement: step 2, image 1 of 2 Porter Cable 690LR Base Latch Replacement: step 2, image 2 of 2
    • Twist the base off the router.
    • You may need to jiggle the base of the router slightly.
  3. Porter Cable 690LR Base Latch Replacement, Base Latch: step 3, image 1 of 2 Porter Cable 690LR Base Latch Replacement, Base Latch: step 3, image 2 of 2
    • Locate the 30 mm bolt and nut attaching the latch to the base.
    • Use a wrench to remove the nut attached to the bolt, freeing the latch from the base.
Jaymes Ullrich
343 Reputation
3 Guides authored
Cal Poly, Team 20-7, Livingston Fall 2016 Member of Cal Poly, Team 20-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G7
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 341
