Porter Cable 690LR Base Panel Replacement
  1. Porter Cable 690LR Base Panel Replacement, Base: step 1, image 1 of 2 Porter Cable 690LR Base Panel Replacement, Base: step 1, image 2 of 2
    • Undo the black latch located on the base of the router by pulling upwards from underneath it.
  2. Porter Cable 690LR Base Panel Replacement: step 2, image 1 of 2 Porter Cable 690LR Base Panel Replacement: step 2, image 2 of 2
    • Twist the base off the router.
    • You may need to jiggle the base of the router slightly.
  3. Porter Cable 690LR Base Panel Replacement, Base Panel: step 3, image 1 of 2 Porter Cable 690LR Base Panel Replacement, Base Panel: step 3, image 2 of 2
    • Orient the base so the black circular plate is facing you. Locate the three silver screw heads.
    • Use a flathead screwdriver to take off the three 10 mm screws.
Emma Stine
273 Reputation
2 Guides authored
Cal Poly, Team 20-7, Livingston Fall 2016 Member of Cal Poly, Team 20-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G7
4 Members
6 Guides authored
1 Guide Comment
Aynı ürünü kullanıyorum..! Son birkaç yıldır Porter Cable ürünlerini kullanıyorum
Ancak bunu bu siteden satın aldım - https://www.raptorsupplies.com/b/porter-...
Omer Polat - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 296
