Porter-Cable 382 On/ Off Switch Replacement
  1. Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: step 1, image 1 of 2 Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: step 1, image 2 of 2
    • First, locate the three screws on the top of the sander.
    • Using a screw driver with a size T20 star bit, unscrew the screws by turning them to the left.
  2. Porter-Cable 382 On/ Off Switch Replacement: step 2, image 1 of 2 Porter-Cable 382 On/ Off Switch Replacement: step 2, image 2 of 2
    • Locate your on off switch and in order to remove it you must slide it out of its slot.
    • This shouldnt require any special tools, just wiggle the switch up and out.
    • Make sure this is done carefully, the switch is attached to two wires that may break if they are pulled on too hard.
  3. Porter-Cable 382 On/ Off Switch Replacement: step 3, image 1 of 1
    • Using a spudger such as the one shown, carefully pry open the connectors as shown just enough to slide the prongs of the switch out.
    • Once both prongs are open, the on-off switch can be removed freely and replaced with a new switch.
Nick O'Sadcia
448 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 361
