Porter-Cable PCE211 Brush Replacement
  1. Porter-Cable PCE211 Brush Replacement, Rear Housing: step 1, image 1 of 2 Porter-Cable PCE211 Brush Replacement, Rear Housing: step 1, image 2 of 2
    • Remove the four 6 mm screws using a Phillips #2 screwdriver.
    • The screws are tight so you will need to use a bit of arm strength.
  2. Porter-Cable PCE211 Brush Replacement: step 2, image 1 of 2 Porter-Cable PCE211 Brush Replacement: step 2, image 2 of 2
    • Pull the rear housing off the back of the impact wrench.
    • Be careful when removing the rear case that loose parts don't get damaged.
  3. Porter-Cable PCE211 Brush Replacement, Brush: step 3, image 1 of 2 Porter-Cable PCE211 Brush Replacement, Brush: step 3, image 2 of 2
    • Remove the brushes connected to the red and black cords.
    • They are not secured so they made drop out naturally.
  4. Porter-Cable PCE211 Brush Replacement: step 4, image 1 of 3 Porter-Cable PCE211 Brush Replacement: step 4, image 2 of 3 Porter-Cable PCE211 Brush Replacement: step 4, image 3 of 3
    • Gently pull each brush off the corresponding cable to avoid damaging the cables.
Layla Berry
678 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 260
