Porter-Cable PCE211 Grip Replacement
  1. Porter-Cable PCE211 Grip Replacement, Gearcase: step 1, image 1 of 2 Porter-Cable PCE211 Grip Replacement, Gearcase: step 1, image 2 of 2
    • Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
  2. Porter-Cable PCE211 Grip Replacement: step 2, image 1 of 3 Porter-Cable PCE211 Grip Replacement: step 2, image 2 of 3 Porter-Cable PCE211 Grip Replacement: step 2, image 3 of 3
    • Grip the body of the impact wrench with one hand and the gearcase in the other and firmly pull to remove it.
    • Be careful about any loose parts when removing the head.
  3. Porter-Cable PCE211 Grip Replacement, Rear Housing: step 3, image 1 of 2 Porter-Cable PCE211 Grip Replacement, Rear Housing: step 3, image 2 of 2
    • Remove the four 6 mm screws using a Phillips #2 screwdriver.
    • The screws are tight so you will need to use a bit of arm strength.
  4. Porter-Cable PCE211 Grip Replacement: step 4, image 1 of 2 Porter-Cable PCE211 Grip Replacement: step 4, image 2 of 2
    • Pull the rear housing off the back of the impact wrench.
    • Be careful when removing the rear case that loose parts don't get damaged.
  5. Porter-Cable PCE211 Grip Replacement, Anvil: step 5, image 1 of 3 Porter-Cable PCE211 Grip Replacement, Anvil: step 5, image 2 of 3 Porter-Cable PCE211 Grip Replacement, Anvil: step 5, image 3 of 3
    • Firmly pull the to remove drill bit holder also known as the anvil.
    • Before replacing the anvil, lubricate the base for the best performance.
  6. Porter-Cable PCE211 Grip Replacement, Motor: step 6, image 1 of 3 Porter-Cable PCE211 Grip Replacement, Motor: step 6, image 2 of 3 Porter-Cable PCE211 Grip Replacement, Motor: step 6, image 3 of 3
    • This section tends to get messy so it would be best to have a paper towel or microfiber towel handy.
    • Pull the motor out with your hands.
  7. Porter-Cable PCE211 Grip Replacement: step 7, image 1 of 3 Porter-Cable PCE211 Grip Replacement: step 7, image 2 of 3 Porter-Cable PCE211 Grip Replacement: step 7, image 3 of 3
    • Wipe out the old grease with a towel. Use the appropriate motor grease for electric tools to lubricate the top area, base of the motor, and the space the motor sits.
  8. Porter-Cable PCE211 Grip Replacement, Grip: step 8, image 1 of 2 Porter-Cable PCE211 Grip Replacement, Grip: step 8, image 2 of 2
    • Using the Phillips #2 screwdriver, remove the three 8 mm screws from the grip of the impact wrench.
  9. Porter-Cable PCE211 Grip Replacement: step 9, image 1 of 2 Porter-Cable PCE211 Grip Replacement: step 9, image 2 of 2
    • Pull the grip from the body of the impact wrench.
Layla Berry
678 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 107
