Porter-Cable PCE211 Rear Housing Replacement
  1. Porter-Cable PCE211 Rear Housing Replacement, Rear Housing: step 1, image 1 of 2 Porter-Cable PCE211 Rear Housing Replacement, Rear Housing: step 1, image 2 of 2
    • Remove the four 6 mm screws using a Phillips #2 screwdriver.
    • The screws are tight so you will need to use a bit of arm strength.
  2. Porter-Cable PCE211 Rear Housing Replacement: step 2, image 1 of 2 Porter-Cable PCE211 Rear Housing Replacement: step 2, image 2 of 2
    • Pull the rear housing off the back of the impact wrench.
    • Be careful when removing the rear case that loose parts don't get damaged.
Layla Berry
678 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 78
