Power Button Board Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Power Button Board Removal, Uncover the back panel screws: step 1, image 1 of 2 Power Button Board Removal, Uncover the back panel screws: step 1, image 2 of 2
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Power Button Board Removal: step 2, image 1 of 3 Power Button Board Removal: step 2, image 2 of 3 Power Button Board Removal: step 2, image 3 of 3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of tweezers or a sharp blade to peel up a corner of the large sticker on the back panel. Use your fingers to peel it farther, just enough to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. Power Button Board Removal, Remove the back panel screws: step 3, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Power Button Board Removal, Unclip the back panel: step 4, image 1 of 3 Power Button Board Removal, Unclip the back panel: step 4, image 2 of 3 Power Button Board Removal, Unclip the back panel: step 4, image 3 of 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Power Button Board Removal: step 5, image 1 of 2 Power Button Board Removal: step 5, image 2 of 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Power Button Board Removal, Remove the back panel: step 6, image 1 of 3 Power Button Board Removal, Remove the back panel: step 6, image 2 of 3 Power Button Board Removal, Remove the back panel: step 6, image 3 of 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Power Button Board Removal: step 7, image 1 of 3 Power Button Board Removal: step 7, image 2 of 3 Power Button Board Removal: step 7, image 3 of 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Power Button Board Removal, Remove the fan screws: step 8, image 1 of 1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
  9. Power Button Board Removal, Disconnect the fan cable: step 9, image 1 of 3 Power Button Board Removal, Disconnect the fan cable: step 9, image 2 of 3 Power Button Board Removal, Disconnect the fan cable: step 9, image 3 of 3
    Buy
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  10. Power Button Board Removal, Remove the fan: step 10, image 1 of 2 Power Button Board Removal, Remove the fan: step 10, image 2 of 2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
  11. Power Button Board Removal, Unlatch the base: step 11, image 1 of 3 Power Button Board Removal, Unlatch the base: step 11, image 2 of 3 Power Button Board Removal, Unlatch the base: step 11, image 3 of 3
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  12. Power Button Board Removal, Twist and remove the base: step 12, image 1 of 3 Power Button Board Removal, Twist and remove the base: step 12, image 2 of 3 Power Button Board Removal, Twist and remove the base: step 12, image 3 of 3
    • Grip the base and rotate it counterclockwise to unlock it from the shell.
    • You may need to hold the locking tab open while you get the base started.
    • Remove the base.
    • During reassembly, drop the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
  13. Power Button Board Removal, Remove the optical drive screws: step 13, image 1 of 2 Power Button Board Removal, Remove the optical drive screws: step 13, image 2 of 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  14. Power Button Board Removal, Remove the vibration isolator: step 14, image 1 of 3 Power Button Board Removal, Remove the vibration isolator: step 14, image 2 of 3 Power Button Board Removal, Remove the vibration isolator: step 14, image 3 of 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  15. Power Button Board Removal, Disconnect the power and data cables: step 15, image 1 of 3 Power Button Board Removal, Disconnect the power and data cables: step 15, image 2 of 3 Power Button Board Removal, Disconnect the power and data cables: step 15, image 3 of 3
    Buy
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
  16. Power Button Board Removal, Remove the optical drive: step 16, image 1 of 2 Power Button Board Removal, Remove the optical drive: step 16, image 2 of 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  17. Power Button Board Removal, Disconnect the USB port cable: step 17, image 1 of 3 Power Button Board Removal, Disconnect the USB port cable: step 17, image 2 of 3 Power Button Board Removal, Disconnect the USB port cable: step 17, image 3 of 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  18. Power Button Board Removal: step 18, image 1 of 2 Power Button Board Removal: step 18, image 2 of 2
    • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • If the USB port cable feels adhered to the metal chassis, use an apply an iOpener or hair dryer to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
  19. Power Button Board Removal, Disconnect the power button cable: step 19, image 1 of 3 Power Button Board Removal, Disconnect the power button cable: step 19, image 2 of 3 Power Button Board Removal, Disconnect the power button cable: step 19, image 3 of 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
  20. Power Button Board Removal, Remove the chassis screws: step 20, image 1 of 1
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  21. Power Button Board Removal, Peel up the USB port cable: step 21, image 1 of 2 Power Button Board Removal, Peel up the USB port cable: step 21, image 2 of 2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
    • Depending on your model of Xbox, the adhesive may be on the underside of the cable. If so, use an iOpener or hair dryer to heat the cable.
  22. Power Button Board Removal, Remove the center chassis assembly: step 22, image 1 of 3 Power Button Board Removal, Remove the center chassis assembly: step 22, image 2 of 3 Power Button Board Removal, Remove the center chassis assembly: step 22, image 3 of 3
    • The center chassis is aligned to the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the center chassis and pull it towards the green fan grille at the top of the shell, uncoupling the guide pegs from the shell.
    • Lift out the center chassis assembly to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
  23. Power Button Board Removal, Separate the power button cable: step 23, image 1 of 2 Power Button Board Removal, Separate the power button cable: step 23, image 2 of 2
    • The power button cable is adhered to the shell with pieces of mild adhesive.
    • Use an iOpener or a hair dryer to heat the power button cable.
  24. Power Button Board Removal: step 24, image 1 of 3 Power Button Board Removal: step 24, image 2 of 3 Power Button Board Removal: step 24, image 3 of 3
    iFixit Opening Picks (Set of 6)
    Buy
    • Be very careful when lifting the cable where it connects to the board. Peel gently, and slide an opening pick under the cable if you're having trouble separating the adhesive.
    • Use your fingers to peel up the power button cable and fully separate it from the shell.
    • During reassembly, use thin double‑sided adhesive to secure the cable. If there's adhesive left and it's still sticky, you can reuse it. If you have a new cable, check it for pre‑installed adhesive and remove any liners.
  25. Power Button Board Removal, Remove the power button board screws: step 25, image 1 of 2 Power Button Board Removal, Remove the power button board screws: step 25, image 2 of 2
    • Use a T8 Torx driver to remove the four 5.5 mm‑long screws securing the power button board.
  26. Power Button Board Removal, Remove the board: step 26, image 1 of 1
    • Remove the power button board.
Finish Line
Spencer Day
158,969 Reputation
1,043 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,918 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 57
