Power Mac G4 Cube Airport Card Replacement
  1. Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: step 1, image 1 of 3 Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: step 1, image 2 of 3 Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: step 1, image 3 of 3
    • Release the handle at the bottom of the Power Mac G4 Cube by pushing it down. Slowly pull out the cube by holding the end of the handle.
    • Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube Airport Card Replacement, Accessing AirPort Card: step 2, image 1 of 2 Power Mac G4 Cube Airport Card Replacement, Accessing AirPort Card: step 2, image 2 of 2
    • Pull outwards on the antenna cable.
    • The cable should pop out of the card without much force.
    • Pull on the clear tab outwards to remove the existing AirPort card
    • Slide in the new AirPort card.
    • Reconnect the antenna cable.
8 other people completed this guide.
Ryan Chun
1,076 Reputation
7 Guides authored
Cal Poly, Team 2-7, Johann Summer 2010 Member of Cal Poly, Team 2-7, Johann Summer 2010
CPSU-JOHANN-R10S2G7
5 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 35
All Time: 9,929
